Need help with engine swap!
Old Jul 13, 2003 | 08:44 PM
awalk2005's Avatar
Default Need help with engine swap!
i have a 99 civic ex with a D16 engine and i want to swap it with a B16 or B18. what will i need to modify? will my transmission from the D16 work with a B16 or B18?
Old Jul 13, 2003 | 08:46 PM
civicrtype's Avatar
Default Re: Need help with engine swap! (awalk2005)
No it will not work: D series trans are not compatible wit B series motors
You will need complete swap: Engine, Trans, Shift linkage, Axles, halfshaft, ecu, and various mounts from the 99-00 SI.
Old Jul 13, 2003 | 11:32 PM
Aldeezy's Avatar
Default Re: Need help with engine swap! (civicrtype)
like the guy above said no your d series tranny is not compatible with a b series motor.just type in b16 or b18 in the search engine and you will a lot of helpful threads that will tell you all the parts you need.good luck man!
Old Jul 13, 2003 | 11:34 PM
GTlvr82's Avatar
Default Re: Need help with engine swap! (all-mota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mota &raquo;</TD></TR><TR><TD CLASS="quote">just type in b16 or b18 in the search engine and you will a lot of helpful threads that will tell you all the parts you need.good luck man! </TD></TR></TABLE> Good nOOb...*pats head*...I love when we get guys like you in here...that have a head on their shoulders.
Old Jul 14, 2003 | 04:14 AM
JICB16B's Avatar
i did the ctr b16b motor into my 2000 civic ex swap was easy
Old Jul 14, 2003 | 05:54 AM
Bigjon
Guest
Posts: n/a
Default Re: Need help with engine swap! (2kB16B)
http://www.hondaswap.com
http://www.hybridgarage.com/
these links should help you
I think you should swap in an obdII b18b. I know somebody that has an ecu for sale.
gheinrich
Honda Civic (2006 - 2015)
Mar 19, 2014 10:04 PM
loveformycivic
14
Sep 8, 2013 01:37 PM
95EG2
15
Dec 2, 2009 01:34 PM
supersonics1996
Apr 17, 2006 12:32 PM
newera3og
Oct 18, 2005 12:35 PM
