Should I replace the fuel filter?
Old Jul 13, 2003 | 07:52 PM
rus's Avatar
rus
Default Should I replace the fuel filter?
1999 Civic, about 65K on the clock. Never had the fuel filter replaced. Should I bother changing it?
Rus
Old Jul 13, 2003 | 07:54 PM
Eee Pee's Avatar
Default Re: Should I replace the fuel filter? (rus)
Sure.
It's easy enough, and since you thought about it, you might as well.
Old Jul 13, 2003 | 09:49 PM
N~FaMouSKhMerBoi's Avatar
Default Re: Should I replace the fuel filter? (Eee Pee)
if you change it..will you even notice any difference? and how often are you suppose to change it?
Old Jul 13, 2003 | 09:53 PM
Spartanic's Avatar
If you do decided to change your fuel filter then make sure its OEM Honda and not some cheap crap from the local auto store. Remember that Honda makes the best parts for its cars and that 3rd party manufacters are just in the market to make money so their parts are crappier, thus the cheaper price as well.
Old Jul 13, 2003 | 10:10 PM
Pho Real's Avatar
Default Re: Should I replace the fuel filter? (N~FaMouSKhMerBoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N~FaMouSKhMerBoi &raquo;</TD></TR><TR><TD CLASS="quote">if you change it..will you even notice any difference? and how often are you suppose to change it?</TD></TR></TABLE>
Give or take 5 mental horses
Old Jul 13, 2003 | 10:55 PM
TuCKiNaLL4s's Avatar
yeah it shouldnt be no obvious GAIN but after 60something thousand miles and not changing it im sure its a little clogged by now
Old Jul 13, 2003 | 11:21 PM
fowler!'s Avatar
Default Re: Should I replace the fuel filter? (Spartanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spartanic &raquo;</TD></TR><TR><TD CLASS="quote">If you do decided to change your fuel filter then make sure its OEM Honda and not some cheap crap from the local auto store. Remember that Honda makes the best parts for its cars and that 3rd party manufacters are just in the market to make money so their parts are crappier, thus the cheaper price as well. </TD></TR></TABLE>
Or you can buy FRAM who produces many of the oem filters that the dealers mark up 300%
Old Jul 13, 2003 | 11:40 PM
Default Re: Should I replace the fuel filter? (fowleryo)
i agree with fowleryo
Old Jul 13, 2003 | 11:58 PM
built562's Avatar
Default Re: Should I replace the fuel filter? (TuCKiNaLL4s)
true, many car companies use other companies (fram for example) to make their prodects. another example is when i worked at autozone on the top of egr valves i would pull back the sticker and it would say ford on it or whatever car company that it was for. so many parts are not actually oem as you think.
do you think honda really makes their own filters and fluids for their cars? no they just pay a company to box them differently.
Old Jul 14, 2003 | 12:05 AM
afgvwracer
Guest
Posts: n/a
Default Re: Should I replace the fuel filter? (akumaracer)
i thought you never had to change your fuel filter unless it got clogged....
or had a defect?
arent they made to last the life of the car?
Old Jul 14, 2003 | 12:11 AM
BI8B's Avatar
i would just replace it since it only cost about $20 for an OEM filter.
Old Jul 14, 2003 | 12:15 AM
degooser's Avatar
Default Re: Should I replace the fuel filter? (afgvwracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afgvwracer &raquo;</TD></TR><TR><TD CLASS="quote">i thought you never had to change your fuel filter unless it got clogged....
or had a defect?
arent they made to last the life of the car?</TD></TR></TABLE>
nope you need to change..it like every 2 years or something..i cant remember where i read that but its more often than you would think....
Old Jul 14, 2003 | 01:52 AM
goodbyegti's Avatar
True about Honda using other companies to manufacture products but it's usually to their own specification not the companies, that way Honda might as well have made it. Honda Engine Oil's a good example, its not made by Honda but is made to their specifications which is why its best suited to VTEC engines, same with Honda MTF...
Old Jul 14, 2003 | 04:20 AM
avex's Avatar
my old fuel filter was clogged, causing me to run lean. I replaced it and everything was fixed.
Old Jul 14, 2003 | 04:43 AM
DSeriesBeeKilla's Avatar
yes honda recommends replacin' it after 60k.....and every 60k after that.....
Rob.
71
Dec 14, 2009 09:23 PM
itgrowsind
Sep 5, 2008 03:54 PM
jhony_ej6
Jul 11, 2008 09:55 AM
ramz7887
Oct 26, 2003 08:02 PM
4505
Oct 10, 2003 09:40 AM
