TPS code from my ecu???????????
Old Jul 13, 2003 | 03:57 PM
dabomb's Avatar
Default TPS code from my ecu???????????
my ecu is giving me a code of 7 flashes which i was told is a throttle position sensor. if this is true how can i go about troubleshooting the fault? i checked the wiring of the plug for the sensor and they seem to look ok. i got the code on friday morning and i was able to get rid of the code by disconnecting the battery for a couple of minutes. but while half way through my first pass on the track the light came on and i got the same code and now i cant get rid of it. i was told by a local shop that you cannot buy that sensor and that i would have to buy a new throttle body? i need help boys and girls, thanks
Old Jul 13, 2003 | 06:28 PM
quik1's Avatar
Default Re: TPS code from my ecu??????????? (dabomb)
Hey Ryan. Its Kevin with the yellow hatch. I have a spare tps sensor that you can have. Give me a call.
Old Jul 13, 2003 | 09:08 PM
dabomb's Avatar
Default Re: TPS code from my ecu??????????? (quik1)
kevin do you have any extra throttle bodies?
Old Jul 14, 2003 | 10:15 AM
quik1's Avatar
I've got a p30 one but its a little smaller than yours ( 58 vs 60 mm ). I've also got a b20 one that is a 62mm but i'm not sure if it'll fit on your intake, you could ask around. Also I must have lost your number somewhere so give me a call, I figured out the problem with my car so i'm a go with test and tune.
Modified by quik1 at 8:05 PM 7/14/2003
d601
Jul 29, 2011 05:04 PM
VTECth1s
Aug 5, 2006 03:44 PM
rasta420
43
Feb 16, 2004 12:39 AM
RedHackBatch
May 6, 2003 06:13 PM
