Brake Light won't go off...!
Old Jul 12, 2003 | 09:58 PM
Gonzo_SiR's Avatar
Default Brake Light won't go off...!
I installed my foglights today, and don't even remember messing with any other connections but the battery terminals and the grounds... Now my brake light is on indefinately.. WTF?! Any suggestions...?
Old Jul 13, 2003 | 07:08 PM
warrick's Avatar
Default Re: Brake Light won't go off...! (Gonzo_SiR)
... now that.. is weird.
if you can find a wiring diagram for your car, I'd say start with that and trace the wiring from the pedal... I can't think of anything else at alll
Old Jul 17, 2003 | 05:35 PM
arsenaldragster's Avatar
Default Re: Brake Light won't go off...! (warric_k)
is the brake light only on when you turn your lights on? if so you might want to check all your bulbs. make sure they are the correct filament (spelling?) anyway if its ok then check your wiring for those fog lights. btw. why are you putting fog lights on in the middle of summer???
Old Jul 19, 2003 | 12:50 PM
jsmurfy's Avatar
Default Re: Brake Light won't go off...! (arsenaldragster)
maybe its really foggy
Old Jul 19, 2003 | 02:03 PM
rjr162's Avatar
Default Re: Brake Light won't go off...! (jsmurfy)
check your brake fluid level... it being even a little low will trigger the light. Top it off and see if it goes away
Tech-Nics
Nov 1, 2022 07:06 PM
caseythefalcon
Mar 30, 2013 03:24 PM
nicolaselias
Dec 22, 2011 03:58 PM
94civicoupe
Oct 16, 2006 06:09 PM
92accord4life
May 2, 2002 02:02 PM
