hooking up a LED light to a switch?
Old Jul 19, 2003 | 11:33 AM
nonvtecLS's Avatar
Default hooking up a LED light to a switch?
how do you hook up a LED light to a switch? Or many LED lights to a switch? thanks for the help!
Old Jul 19, 2003 | 04:14 PM
honda_joe's Avatar
Default Re: hooking up a LED light to a switch? (nonvtecLS)
First of all, what kind of LED? If its a generic PLAIN LED, you need a resistor. A 220 or 330 OHM is good.
If this is an AUTOMOTIVE LED, you're ok.
All you need to do is hook up the red wire to a "hot" wire in your car. Then, hook the black wire to one side of the switch and then another wire from the other side of the switch to a ground point. If the switch is lighted, you hook the 3rd wire to a "hot" wire to make the switch light up. In that case, it should tell you which wires go where.
Rhys!
Jun 26, 2013 03:50 AM
93DA9
Lighting
Nov 24, 2008 09:47 PM
deadline
Apr 24, 2007 08:09 PM
mugenDA9 lover
Sep 24, 2006 05:25 PM
