SRS light
Ok, did a search, no result. I installed a momo steering wheels, and of course the SRS light came on. Just wondering is there a way to turn that light off?
P.S. I've heard that even the driver's airbag is out, the passanger side should still work properly (individual cable for each side), is that right?
thanx,
CS
[Modified by CS, 8:34 PM 7/31/2001]
thanx,
CS
heh, i installed my new momo last night and my light is on as well. i didn't want to pull the fuse, as that would disable the passenger side airbag as well...
any thoughts, anyone?
tia...
tia...
pulling the bulb should work but what if there's a problem with the passenger airbag
I personally don't like airbags, I have a fear that they'll suddenly blow up in your face
Anyone else have this fear
good one (tape), I thought of that too, but I was reading menu for Integra, just wondering if I reconnect the wire of the driver's side of the air bag will do it..... anyone tried?
If I take the bulb out, does the passenger side air bag still work?
thanx,
CS
thanx,
CS
Neh, I took out the cluster (very easy with only two screws on top) and put electrical tape on the inside of the cutout hole for the SRS light. I tried pulling the bulb off but it's on pretty tight and it's one of those press-in type. So instead of breaking the bulb I just put tape over the hole. It's looks liek the light was never there. As for the passenger SRS, it will still work. It has its own wires.
PDXHatchback
Mar 23, 2003 06:32 PM
