Fuel Pressure Regulator problem???
Old Jul 11, 2003 | 09:45 PM
importimage's Avatar
Default Fuel Pressure Regulator problem???
I have a B&M Fuel Pressure Regulator. I have reason to believe that it may be defective because I am throwing a code 43 (Fuel Supply System). I have changed my 02 sensor because it has been a long time anyways. I do not have any vacume leaks and the fuel pump seems to be working ok (meaning that I can hear the pump come on). Any sugggestions???
Old Jul 11, 2003 | 10:40 PM
irev210's Avatar
Default Re: Fuel Pressure Regulator problem??? (importimage)
do you have a fuel pressure gauge to see what fuel pressure ur running
Old Jul 12, 2003 | 04:32 PM
Default Re: Fuel Pressure Regulator problem??? (irev210)
I do not have a fuel pressure gauge. Any suggestions as to which one to buy??
Old Jul 12, 2003 | 04:41 PM
J2turbo21's Avatar
Get a B&M gauge from titanmotorsports.com there 35bux.Also i dont think its your FPR because the FPR doesnt have a sensor on it.
Old Jul 12, 2003 | 11:06 PM
Default Re: Fuel Pressure Regulator problem??? (J2turbo21)
If you do not hink this is my problem, do you have any suggestions as to what it may be??
hondapowerb16a2
Mar 20, 2010 01:15 AM
B18EG6
Jun 15, 2004 11:19 AM
blykins
Apr 16, 2003 12:22 PM
