Hondata quirk..
Old Jul 11, 2003 | 01:13 PM
MayhemSi's Avatar
Default Hondata quirk..
Ok.. i posted a while back about a random CEL that comes on with my s100b setup, but when I turn off the car and turn it back on again it doesn't store the code. Well now my speedometer just stopped working and the CEL is on but still doesn't get stored. Any ideas Hondata gurus?
Old Jul 11, 2003 | 01:49 PM
M-EJ1's Avatar
Default Re: Hondata quirk.. (MayhemSi)
Sounds like an unrelated problem to me... if the speedo stops working, it could mean that your speed sensor is gone. Does VTEC still engage or no?
Sorry if I'm off-track here, I'm just making a suggestion based on previous experiences... maybe someone else has some other ideas.
(BTW, cheap plug... if it IS the speed sensor, I have one for sale, check the sig. )
Old Jul 11, 2003 | 01:50 PM
MayhemSi's Avatar
Default Re: Hondata quirk.. (M-EJ1)
Vtec still engages fine. The car drives normal just no speedo.
Old Jul 11, 2003 | 01:54 PM
shermanyang's Avatar
check and see what the code is. maybe it's a short somewhere...they come and go as pleased...could be many things.
Old Jul 11, 2003 | 02:38 PM
Spunkster's Avatar
Speedo problem sounds like a blown fuse...I had the same problem. Has nothign to do with Hondata.
Check the CEL before you turn your car off and then you can read the code.
Modified by Spunkster at 8:53 PM 7/11/2003
Old Jul 11, 2003 | 02:50 PM
IloveNewt's Avatar
Default Re: Hondata quirk.. (Spunkster)
could be ur ecu
jdmlife
Mar 2, 2005 04:34 AM
KiNG $h!t
Nov 21, 2004 12:03 PM
FOrSfEd
Nov 16, 2003 03:09 PM
seek167
Jul 1, 2002 03:48 AM
