reading posts, now confused - SC61 & SC63 - need specs and advice
Old Jul 11, 2003 | 12:52 PM
Greyout's Avatar
Default reading posts, now confused - SC61 & SC63 - need specs and advice
I am doing my first turbo build up, so I apologize if any of this seems too n00bish.
I was originally going to go with a T3/60-1 for my prelude, but it seems that the SC61 is a more popular option.
Questions:
- SC61 is a regular T3 flange that will fit my T3-flanged manifold, right?
- what are the differences between a SC61 and SC63?
- What turbine A/R's can I get the SC61 & SC63 in? I was going to use either the .83 or .64 on the 60-1, guess I'm looking for something similar with the SC61 /
SC63...
-stage 3 vs. stage 5 turbine - whats different, how does it affect the performance, and would it affect what A/R I choose?
most important part - my minimum goal: Street driven, full boost by 4,000 RPM, and 400 whp on 93 octane. I'll be revving a 2.4L H-series to about 7500-8000.
Old Jul 11, 2003 | 01:05 PM
ID_ten_T's Avatar
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (Greyout)
i'd say talk to either precision directly or any of the dealers here. they will be the most knowledgeable. i know art (arturbo) and mike (motormatrix) are dealers and i am sure there are more.
Old Jul 11, 2003 | 01:10 PM
b18cTurbo's Avatar
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (ID_ten_T)
https://honda-tech.com/zerothread?id=557694
Old Jul 11, 2003 | 01:13 PM
done's Avatar
both sc61 and sc63 are 4 bolt flanges, so yes they wil fit a t3 4 bolt manifold.
sc63 has a bigger shaft then the sc61
stage 3 vs stage 5, they had a dyno not long ago, showing the differences, i think stage 3 made more midrange, but stage 5 was more up top.
depends which housing you want also, either the S or the E. the E will spool sooner..
hope i helped a little.
Old Jul 11, 2003 | 01:15 PM
Boostfed's Avatar
New User
Both the SC61 and SC63 come in T3 turbine sizes. The SC61 is available also as a straight T04 turbo. On the T3 only .48 and .63 A/R housings are available. On the T4 then .58, .68 and .81 A/R are available. I am sure pretty sure Precision could do or will do or already make the SC63 as a straight T4 turbo. The SC63 is a big shaft turbo also . Specs are
SC63 specs inducer=2.476" major=3.310"
SC61 specs inducer=2.416" major=3.227"
_______
In T3 they are available with 76 trim T350 wheels aka Stage V and also the 69 trim T31? (Art?) Hope this helps. OH yeah from what Precision Rod told me the SC61 flows 68lbs/min and the SC63 69lbs/min. SC61 rated for 680hp crank and SC63 rated 700hp crank.
The SC61 comes standard with a T04E housing with a T04S option adn SC63 is standard with T04E housing and possibly the T04S also.
Old Jul 11, 2003 | 01:30 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (Boostfed)
the sc63 I used to run on my street car had a 30 degree clipped p trim wheel. it was not a stage 5 on my car. by the way if you have some ***** they could even put a gtq wheel on the sc63 which is what i am thinking of doing for my next turbo. i have seen the sc63 make 710whp.the sc61 may also make that but i havent seen anyone push it yet. ithe sc63 is big shaft which gives it some more lag but less shaft play.
Old Jul 11, 2003 | 03:43 PM
Quick 200k Mile Motor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">most important part - my minimum goal: Street driven, full boost by 4,000 RPM, and 400 whp on 93 octane. I'll be revving a 2.4L H-series to about 7500-8000.</TD></TR></TABLE>
if you decide to get the SC61, definitely go with the T04S housing.
i think it'll be perfect!
Old Jul 11, 2003 | 07:18 PM
I am a bad person
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (Quick 200k Mile Motor)
there were no significant gains other than more lag with the t04s from what i was told.
Old Jul 11, 2003 | 10:40 PM
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (MotorMatrix.com)
yup, a little lag on a 1.8L gsr
Old Mar 9, 2004 | 08:50 PM
1SlowSi's Avatar
Whats the outlet size on the turbine? Cuase i dont want to run a 2.5" DP if the outlet is bigger, but its the same size or smalled then im good! thanks.
Old Mar 11, 2004 | 08:04 PM
1SlowSi's Avatar
bump
Old Mar 11, 2004 | 10:01 PM
G
sh!t happens.
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (1SlowSi)
what rpm does the sc63 spool up at?
what rpms does the sc61 spool up at?
Old Mar 12, 2004 | 01:05 AM
1SlowSi's Avatar
Default Re: reading posts, now confused - SC61 & SC63 - need specs and advice (G"UNIT)
Thats a very broad question. It all depends on the setup ya know! The SC61 is known to fully spool around 5500+ maybe lower with a bigger displacement. The SC63 i really dont know... maybe add a couple 100 rpms. thats all i know. ive seen full boost with the SC61 by 5000k. thats with a 85.5mm bore and everything else wide open.
Old Mar 20, 2004 | 02:16 AM
1SlowSi's Avatar
What is the size of the outlet on the turbine? Please say 2.5 or less. The reason why i ask is because i want to run a 2.5 DP. If the oulet is lets say 2.6, and i run the 2.5 how much resistance will that cause? thanks.
Old Mar 21, 2004 | 08:15 PM
1SlowSi's Avatar
bump anyone????
Old Apr 11, 2005 | 07:51 AM
seamoss's Avatar
____________________
sean-sports
Feb 1, 2007 09:53 PM
nebulight
Nov 9, 2004 10:37 PM
underpressure02
Oct 29, 2003 06:47 AM
CRiX
Jan 23, 2003 08:57 PM
