which header
Old Jul 11, 2003 | 09:36 AM
StlSupra's Avatar
Default which header
i've happened to come into two different headers for my d16.
1) is dc sports header - think most people know about this one.
2) is holley airmass extreme (blue one)
so far i only have one issue. dc has the 02 bung hole right at the collector. so it see's all 4 cyl. the holley has the bung where the #1 and #4 cyls meet. so it only see's those too. in my mind that could lead to problems. am i just being too overly critical? would there actually be a performance difference between the two?
Old Jul 11, 2003 | 09:50 AM
DJ_SaNdOz's Avatar
Default Re: which header (StlSupra)
yes- the dc is better
Old Jul 11, 2003 | 10:02 AM
EL Vap133's Avatar
DC, definitely....
Old Jul 11, 2003 | 10:12 AM
StlSupra's Avatar
Default Re: which header (DJ_SaNdOz)
can you explain what makes it better? can't find any proven dyno #'s
Old Jul 11, 2003 | 10:28 AM
DJ_SaNdOz's Avatar
1.) the O2 placment that you already noticed
2.) quality R&D
3.) quality parts
4.) proven customer satisfaction w/ that product
5.) b/c it's not an ebay special
Old Jul 11, 2003 | 10:35 AM
StlSupra's Avatar
i'm debating the o2 placement. What i know of o2's is that they should be within 15 inches of manifold for optimal heating of the sensor. When properly warmed it will read a truer reading. Since i am more concerned about power output that means i will mostly be WOT on the track so i would be in open loop mode of the ecu, so it will ignore the readings from the o2.
i really want to dyno both headers and see if there is a difference. however that lowers the price i could turn around and sell the other one for.
Old Jul 11, 2003 | 10:39 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StlSupra &raquo;</TD></TR><TR><TD CLASS="quote">i'm debating the o2 placement. What i know of o2's is that they should be within 15 inches of manifold for optimal heating of the sensor. When properly warmed it will read a truer reading. Since i am more concerned about power output that means i will mostly be WOT on the track so i would be in open loop mode of the ecu, so it will ignore the readings from the o2.
i really want to dyno both headers and see if there is a difference. however that lowers the price i could turn around and sell the other one for.</TD></TR></TABLE>
Please dyno if you have the means- I would like to see as well. I'm currently running a cheap "SS Autochrome" header from ebay that was super cheap & I got noticible gains from it; but I'd really like to see some dyno's of the diff header's (yes plural, as in multiple )
blurrek4
Sep 6, 2010 08:18 PM
krysted9354
12
Dec 29, 2008 11:09 PM
DA9toED6
Southeast (Sales)
Jan 4, 2007 07:22 PM
nota-ex
May 10, 2004 06:13 AM
kylefakesi-r
Oct 29, 2003 02:22 PM
