upper ball joint removal from the knuckle????
Old Jul 10, 2003 | 11:11 PM
accordfreak's Avatar
Default upper ball joint removal from the knuckle????
on the helms manual it says to remove the 40mm ring.. i can't find a ring.. is it above the knuckle or below it?? i have that special tool also to remove the ball joint from the knucle.. i need to take the whole ball joint OUT... please let me know..
btw i already seperated the arm from the ball joint... and now i have to take out the ball joint itself.
thanks
Old Jul 11, 2003 | 03:39 AM
urbanlegend21's Avatar
New User
Default Re: upper ball joint removal from the knuckle???? (accordfreak)
that is the ring surrounding the ball joint boot, it is the only one I had to remov
Old Jul 11, 2003 | 03:04 PM
Default Re: upper ball joint removal from the knuckle???? (urbanlegend21)
where do u get the tool to remove the ball joint itself? it seems as though they only rent ones that seperate the arm from the joint...
djnikko
Jun 11, 2010 10:19 AM
HONDRETTI
Dec 31, 2008 05:06 PM
ultraforce77
Jul 15, 2004 02:59 PM
accordfreak
Jul 11, 2003 10:17 AM
Flamenco-T
Aug 21, 2002 11:49 PM
