which pistons will yield 9.5-10.0 on ls/vtec turbo?
Old Jul 10, 2003 | 05:31 PM
civicguy's Avatar
Default which pistons will yield 9.5-10.0 on ls/vtec turbo?
im looking to get cp pistons but dont know which one will get me around 9.5-10.0
here is the set up:
b18a block
b16a2 head
81mm bore
oem head gasket
i need help on this please
Old Jul 10, 2003 | 05:36 PM
rOby's Avatar
Default Re: which pistons will yield 9.5-10.0 on ls/vtec turbo? (civicguy)
would depend on ur crank too, rod height. ehh. i think if everything is standard, 9.5 cr pistons will net you 9.7 cr , right smack dab in the middle. a b16 head in general will usually increase cr by 2pts or more.
Old Jul 10, 2003 | 05:56 PM
onetwothree's Avatar
Default Re: which pistons will yield 9.5-10.0 on ls/vtec turbo? (rOby)
Well just find out the dome volume of a piston, go to http://www.c-speedracing.com/h...c.php and plug in the calculations
Old Jul 10, 2003 | 07:57 PM
Turbocivic94's Avatar
9:8:1 flat top Je pistons
that's what I got in my lsvtec
Old Jul 10, 2003 | 09:52 PM
speeddave's Avatar
Default Re: which pistons will yield 9.5-10.0 on ls/vtec turbo? (25 PSI CRX)
i have the 8.5:1/8.8:1 weisco's i believe you can get them in 9.5:1 as well. just depends on head cc, etc.. as to what your final comp will be. i used b18a pistons, and was told that the valve reliefs would be fine(same p# as b18c1 i believe), but i still need to clay it to be sure. if your not sure of the valve clearance make sure to check it out. hth
edit: mine came out to 8.8.1 .2 above using 8.5:1 pistons
Gunmetal_B20_Hatch
Dec 30, 2010 11:20 AM
J_SHADOW
May 26, 2008 06:37 PM
drunknbass
Aug 20, 2004 05:40 PM
DLB1994
May 15, 2002 11:42 AM
Integra91LS
Mar 30, 2002 08:49 PM
