Just b00sted the R. Throttle problem. Need help
Hey guys, i just finished my drag gen III on my 01 ITR. Everything went well, but when i took it for a ride today, it just started revving high for some reason. I am running open downpipe because the shop had to order a 3" flex pipe, and i am going to get that welded on tomorrow; however, when i drove the car home, i gave it 1/2 throttle, and hit about 3.5k RPM, and then it just revved up to 6 or so untill i shut the car off. Anyone know what this could be?? It felt like the gas pedal was going down w/ out me pushing it. Any suggestions will be nice. Thanks guys!
( I posted this in the FI forum, but it couldn't hurt to post it here either )
I checked my throttle cable about a million times. Yeah, i thought it may be a fuel line. I will double check it. Thanks guys. Any other suggestions??
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by talagangpinoy »</TD></TR><TR><TD CLASS="quote">throw that **** out
hahahahahaha!! That answer helps all my car problems
</TD></TR></TABLE>hahahahahaha!! That answer helps all my car problems
how would a fuel line do that ?
anyway check the throttle calbe very very closely, and check inside the charge pipe and in the throttle body, something might have got sucked up in there.
could be but im betting not, same **** happened in the Ep 2 days ago and in my R once , the filter came off the intake tube and sealed the tube and kept the tb wot, and scared the **** out of us a few times. somrtihng stuck in the charge pipe or throttle body will cause that , i would check that 1st before going any deeper.
Nameless Warrior
Feb 1, 2007 08:58 AM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
