about jc whitney mandrel pipes
the site says the material is "almuminized steel" so is this aluminum or mild steel? i'm curious because if i order a bov, i need to know what kind of welding is required... thanks
its steel that's dipped in aluminum alloy. it has surface characteristics of aluminum and strength of steel. im guessing to weld it, just tell them its aluminized steel they should know what to do.
it's what any decent muffler shop would use. only ******** use regular steel as it rusts in about 2 weeks. you can weld it just like normal.
BeArDy
Welding / Fabrication
12
May 18, 2011 01:50 AM
AzntaggeR
Mar 21, 2005 08:55 PM
