my engine is getting to much gas with out touching the gas pedal WHY????
Can someone explain to me why is my engine going crazy. It seems like it's getting gas by itself, an it keeps revving by it's self like it's going to blow up. I need to get some ideas so i can drive again. It's a 88 civic hb dx.
how high are the RPM's reaching? Many people have this idle surging problem, there are so many causes to it - no one will be able to diagnose it for you. Someone had a write up on it for every possible cause... mine was the simple one, my idle was too high, so I screwed the little idle screw counter-clockwise to lower my RPM's and it worked perfectly.
I finally found the problem. First off, I took the the top throttle plate off a few days ago and there is a wire gage that u have to remove, and when I took it off I didn't look for loose pieces "very dumb right", so long story made short, there was just a piece of that wire stuck in the bottom throttle plate.
So I finally got it out, the only thing is that I played with the idle a little bit, so I got to adjust it.
Thanks to all that was concerned!!!!!!!!!!!!!!!!
OverCorrupt
Jul 31, 2005 06:22 PM
