prices for all this little maintenance stuff...
Well I'm looking at a 95 Gizzer that needs all this stuff...how much does each item cost?
timing belt
water pump
cam seals
stock tails
thermostat
how much do you think I could sell a set of 17 inch Enkei CDR9's with tires?
timing belt
water pump
cam seals
stock tails
thermostat
Check out http://acuraautomotiveparts.org for OEM parts.
Cam Seal: OEM=$12, STR= $24
Stock Tails: 94-97: $30-$50
98+: $100-$150
98+: $100-$150
For seals, I would stick to the OEM ones, no big reason to use an aftermarket, it's relatively cheap.
Just for reference, a timing belt job at my shop which includes:
OEM-
Timing Belt
Water Pump
Drive Belts
Thermostat
All associated seals (even the oil pump seals on most cars)
Valve Adjustment
and coolant ect.
for $500-600.
OEM-
Timing Belt
Water Pump
Drive Belts
Thermostat
Valve Adjustment
and coolant ect.
for $500-600.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx »</TD></TR><TR><TD CLASS="quote">i dont know much about cam seals....how many do you needs and what is the difference between OEM and that other? Thanks.</TD></TR></TABLE>
You only need to replace one cam seal. The original cam seals only had 1 o-ring and as a result a common problem is that they leak. The redesigned OEM cam seal has 2 orings like the STR ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dased530 »</TD></TR><TR><TD CLASS="quote">water pump $50 ??? sure about that? I was quoted over a hundred for one,... Timing belt for a teg aren't they at auto zone for like $30 and kragens for $50 ?</TD></TR></TABLE>
I usually don't get OEM parts when I do maintenance. However, when I changed my timing belts I didn't want to mess around with a cheap one. So, I spent the $65 to get an OEM one.
chomorro
Jun 22, 2006 08:56 AM
