Which lower tie bar fits with itr sway?
Old Jul 9, 2003 | 05:39 PM
HybridGSR1's Avatar
Default Which lower tie bar fits with itr sway?
i tried installing my old lower tie bar but the sway bar bracket gets in the way, just wondering which lower tie bar would fit and clear the itr sway bar.. pictures would be great!
Old Jul 9, 2003 | 08:14 PM
96IntegraRS's Avatar
Default Re: Which lower tie bar fits with itr sway? (HybridGSR1)
Comptech.
Old Jul 9, 2003 | 08:15 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Which lower tie bar fits with itr sway? (96IntegraRS)
does benen fit?
Old Jul 9, 2003 | 08:19 PM
Calavera's Avatar
Default Re: Which lower tie bar fits with itr sway? (dLo GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">does benen fit?</TD></TR></TABLE>
apparently, it does to some and not to others. Didnt fit in my 97 integra. I needed huge *** spacers to fit a benen tie bar with the itr sway bar /bsq mounting kit.
I have for sale, a Beaks spacer kit if anyones interested btw.
Old Jul 9, 2003 | 09:10 PM
JMod's Avatar
Default Re: Which lower tie bar fits with itr sway? (Calavera)
is your emblem upside down on purpose?
Old Jul 9, 2003 | 09:12 PM
DownBoyDown's Avatar
Yeah with both the beaks kit and Bsq kit you have to use longer bolts with spacers or washers inbetween to clear the sway bar brackets. Beaks sells the longer bolts and spacers for around $10. Beaksproducts.com
But in my opinion Im not sure if the lower tie bar would be that rigid if it was mounted so far away from the body. Not a fact, but just my opinion.
Old Jul 10, 2003 | 04:08 AM
Default Re: Which lower tie bar fits with itr sway? (BucsJosh)
No, I actually bought it that way and have never bothered to change it.... the trunklid was painted and whoever put it back together put it on backwards.
Old Jul 10, 2003 | 05:46 AM
IntEGNYC's Avatar
V for vicious
Old Jul 10, 2003 | 07:50 AM
R.S.'s Avatar
Default Re: Which lower tie bar fits with itr sway? (IntEGNYC)
This is what BSQ5 from Team-integra.net told me when I asked him:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> The following rear lower tie bars work with the Type-R rear swaybar with no further modifications: Spoon, Comptech, Benen and JIC Magic.
Other rear lower tie bars such as the Neuspeed, Skunk2 will work with the Type-R rear swaybar, but you will need a two 1/2" LCA bolts and a two 1/2" spacers which will prevent the tie bar from contacting the swaybar.</TD></TR></TABLE>
Old Jul 10, 2003 | 07:57 AM
tND2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">apparently, it does to some and not to others. Didnt fit in my 97 integra. I needed huge *** spacers to fit a benen tie bar with the itr sway bar /bsq mounting kit.</TD></TR></TABLE>
I have the ITR Sway and a Benen Lower Tie on my '95.. wonder why everything's peace on mine, but not yours?
Old Jul 10, 2003 | 01:38 PM
junglistgsr's Avatar
Default Re: Which lower tie bar fits with itr sway? (tND2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tND2k &raquo;</TD></TR><TR><TD CLASS="quote">
I have the ITR Sway and a Benen Lower Tie on my '95.. wonder why everything's peace on mine, but not yours?</TD></TR></TABLE>
i think when i installed the bar on that car (the car tnd2k currently owns) i mightve put two nuts in between where the LCA mounts and the actual tie bar, but it was a 10 minute install job so my recollection of it is very hazy. i remember putting it on but none of the details.
Old Jul 10, 2003 | 09:53 PM
xsnrgsr
Guest
Posts: n/a
Is it worth it to get the Comptech Swaybar/Tiebar combo? I am on my second integra and I had the BSQ Type-R kit and it was great, and cheap, on my first teg. The comptech one has a price tag of 400 dollars, i think it used to be less. Is it worth the extra 300 for a tie bar and a perfect fit?
Kyles ej1
11
Apr 23, 2005 04:00 AM
revvin9k
Aug 5, 2004 09:14 AM
JFG Kevin
Mar 23, 2004 04:33 AM
Teknic73
Aug 27, 2003 08:16 AM
IntEGNYC
Jan 10, 2003 10:38 AM
