took out waterpump now car wont start HELP
Old Jul 9, 2003 | 03:28 PM
tangb2023
Guest
Posts: n/a
Default took out waterpump now car wont start HELP
hey guys.. i replaced a waterpump on 88 accrord now car wont start.. i turn the bottom pully and the camshaft or top pully wont turn.. dont know much about carboratd cars.. but when i turn the key the bottom pully turns but not the cam. any solutions asap thanks...
Old Jul 9, 2003 | 06:12 PM
jweller's Avatar
Default Re: took out waterpump now car wont start HELP (tangb2023)
timing belt isn't on right or isn't tight enough
Old Jul 9, 2003 | 07:19 PM
Stripped Honda's Avatar
99-0104
Default Re: took out waterpump now car wont start HELP (jweller)
fix your timing belt you may have already messed up your vlaves.... you have to put everything to top dead center and put the belt back on and loosen the tensioner and then tighten it again .... why did you even mess with the timing belt if you only needed a water pump they are external on that car
Old Jul 9, 2003 | 08:03 PM
tangb2023
Guest
Posts: n/a
Default Re: took out waterpump now car wont start HELP (Stripped Honda)
i did not mess with timing belt.. just took the valve cover off to see if it will turn.. thanks though.. will check tomorrow ..
Old Jul 9, 2003 | 08:08 PM
Conechaser's Avatar
Is the timing belt broken?
Old Jul 9, 2003 | 09:17 PM
tangb2023
Guest
Posts: n/a
Default Re: (94Accord)
no timing belt is not broken...
doc500
Apr 13, 2012 05:52 PM
green_si
18
Mar 3, 2010 03:24 PM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
valve79
Dec 29, 2004 03:20 AM
integrasi
Oct 30, 2003 08:12 PM
