What's this cel code?
Old Jul 9, 2003 | 10:53 AM
EKtypeRhaTcH's Avatar
Default What's this cel code?
i checked cel came on today and i checked for what code it comes up with. this is my first time doing this but right when the key is on the on position it flashes once, then about 2 seconds later it flashes 5 in a row. anyone know which code this is and what is wrong with mycar?
Old Jul 9, 2003 | 11:11 AM
allmtr's Avatar
Default Re: What's this cel code? (EKtypeRhaTcH)
http://tech.hybridgarage.com/tech/codes.html
Old Jul 9, 2003 | 11:12 AM
Kataku2K3's Avatar
You say that it flashes on when you turn your ignition on... By that would you mean that it just turns on and off as it normally does or is it throwing like a code 1 (short flash) or 10 (long flash)??? If you have a lil jumper shorting your SCS connector take it out, turn the car to ACC, then jump the SCS again... If you get only the 5 flashes then I'm pretty sure your car is throwing a code 5... That means something is up with the MAP or it's wiring... Do you by chance have a A/F controller??? That can sometimes pop up a MAP code... Let me know and I'll get back to ya as soon as I can... Good Luck
Old Jul 9, 2003 | 11:33 AM
no i dont have an a/f controller i dont have anything besides an intake. the only thing i changed was i changed my throttle cable because it snapped. thanx let me know
Old Jul 9, 2003 | 11:37 AM
bump, if it is that what do i do to fix it?
Bunger
Sep 12, 2011 09:00 AM
Mr.Death
Apr 30, 2010 05:51 PM
lazyxmofo
Feb 13, 2009 06:43 AM
93b18civic
Mar 21, 2004 06:48 PM
95sihb
Nov 14, 2002 05:28 AM
