VX Wheels
If I bought 13" VX wheels and put them on my civic would that put me out of the stock class? I have 13" steelies right now so I wouldn't think so. Also, is it worth bothering with these wheels, I mean, are they too small to even be worth buying for autox use?
They are worth it if you want to remain in stock class. AFAIK, the VX wheels are 13x5, same as the stock steelies, but weigh a measerly 10lbs or so, which is obviously good. I think also the offset is the same or very close. You need to be within about +/- 6mm to be legal. Mount some 185-60-13, 205-60-13 or even 215-50-13 race tires on those suckas and you're set. When you'll be ready to change classes like a move to STS, or SP, P, SM etc, then you should get something much wider, like a 13x8...
I have vx rims on my ef and they are like pizza cutters but that is because I"m only running 175/70/13 on them. They only weigh 8lbs. If you do get vx rims upgrade the tires asap because your not going to get any traction around turns, its going to be all understeer thats all I do around turns and I light the tires up as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak »</TD></TR><TR><TD CLASS="quote">225 is widest tire allowed in sts, 225 will be too small for 8" rim. FYI. SM is a different story, 8" is fine there.</TD></TR></TABLE>
to expand on that, 7.5" is the widest wheel you can run in STS
The DX Rex
18
Feb 22, 2005 11:52 PM
ChingonGSR
13
Jan 31, 2004 02:50 AM
utensil
19
Jul 4, 2001 03:54 PM
Downey
Jun 23, 2001 03:57 PM
