Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
VX Wheels
Old Jul 9, 2003 | 06:54 AM
jaxle's Avatar
Default VX Wheels
If I bought 13" VX wheels and put them on my civic would that put me out of the stock class? I have 13" steelies right now so I wouldn't think so. Also, is it worth bothering with these wheels, I mean, are they too small to even be worth buying for autox use?
Old Jul 9, 2003 | 07:01 AM
jsi's Avatar
jsi
Default Re: VX Wheels (jaxle)
They are worth it if you want to remain in stock class. AFAIK, the VX wheels are 13x5, same as the stock steelies, but weigh a measerly 10lbs or so, which is obviously good. I think also the offset is the same or very close. You need to be within about +/- 6mm to be legal. Mount some 185-60-13, 205-60-13 or even 215-50-13 race tires on those suckas and you're set. When you'll be ready to change classes like a move to STS, or SP, P, SM etc, then you should get something much wider, like a 13x8...
Old Jul 9, 2003 | 06:25 PM
SlapSmak's Avatar
Default Re: VX Wheels (jsi)
225 is widest tire allowed in sts, 225 will be too small for 8" rim. FYI. SM is a different story, 8" is fine there.
Old Jul 9, 2003 | 07:25 PM
goforbroke's Avatar
MEAT PATTY
Default Re: VX Wheels (SlapSmak)
I have vx rims on my ef and they are like pizza cutters but that is because I"m only running 175/70/13 on them. They only weigh 8lbs. If you do get vx rims upgrade the tires asap because your not going to get any traction around turns, its going to be all understeer thats all I do around turns and I light the tires up as well.
Old Jul 9, 2003 | 07:32 PM
ArcticFreeze's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">225 is widest tire allowed in sts, 225 will be too small for 8" rim. FYI. SM is a different story, 8" is fine there.</TD></TR></TABLE>
to expand on that, 7.5" is the widest wheel you can run in STS
Old Jul 10, 2003 | 07:51 AM
Civic44's Avatar
Default Re: VX Wheels (ArcticFreeze)
I use VX wheels for road racing on my EF. The widest I would go is 205-60-13 on those wheels. I've seen drag guys go wider, but I wouldn't...
Old Jul 10, 2003 | 01:36 PM
Eee Pee's Avatar
Default Re: VX Wheels (Civic44)
Or a 20x8x13 cantilevered slick will fit.
The front won't rub, and the back needs a 1/4 spacer, and still sligtly rubs.
96MidoriHatch
Feb 28, 2005 02:51 PM
The DX Rex
18
Feb 22, 2005 11:52 PM
ChingonGSR
13
Jan 31, 2004 02:50 AM
utensil
19
Jul 4, 2001 03:54 PM
Downey
Jun 23, 2001 03:57 PM
