Cleaned Filter (Lost power?)
Old Jul 9, 2003 | 06:24 AM
TypeR 01 886's Avatar
Default Cleaned Filter (Lost power?)
I have a short ram intake from my GSR
I just cleaned it with the K&N Recharging kit. I have notive three things that I though would be the complete oppotise.
1) Not as loud
2) Decreased throttle response
3) Dont hear the slight whistle that I used to like at partial throttle
Is this normal that anybody else knows of? I know its not that big of a deal, just wondering if anybody else has experienced this and if its normal until some of the "grease" drys off?
Old Jul 9, 2003 | 06:26 AM
NunRacer's Avatar
Default Re: Cleaned Filter (TypeR 01 886)
Did you use too much of the oil on the filter?
Old Jul 9, 2003 | 06:57 AM
Default Re: Cleaned Filter (NunRacer)
Possibly, is there a way I can take some of the oil off? Will it hurt anything having too much oil on it?
Old Jul 9, 2003 | 06:59 AM
NunRacer's Avatar
Try to sponge some off or if you have time let it drip off, that will be a sure sign of too much oil.
Old Jul 9, 2003 | 07:15 AM
hionvtecxda6's Avatar
is it a k&n filter? can you use the recharge kit on generic filters?
Old Jul 9, 2003 | 07:29 AM
Default Re: Cleaned Filter (hionvtecxda6)
I would think, "K&N style air filter" I guess its a ripoff of k&n
I wonder if I should just go buy a new filter. I just hope I didnt/dont suck of and of that "oil" into the engine, I doubt it would hurt anything.
After I sprayed it... yes I let some drip off for about 30 minutes. (some did drip off) and that was last night. That car sat overnight and I drove into work this morning and noticed what I mentioned above.
Old Jul 9, 2003 | 10:54 AM
kkim's Avatar
yeah, sounds like you might have put too much oil on the filter. however, it should improve over the next couple of days. once the carrier evaporates and only the oil is left, the filter should be breathing as it once did. no need to buy another filter.
did you let the filter air dry before reoiling?
Old Jul 9, 2003 | 11:03 AM
Big Phat R's Avatar
you likely put too much oil on the filter.
Old Jul 9, 2003 | 11:17 AM
shadyCTR's Avatar
Default Re: Cleaned Filter (Big Phat R)
its got to be the red valve cover!
Old Jul 9, 2003 | 11:49 AM
MugenizedR's Avatar
Default Re: Cleaned Filter (shadyCTR)
Take off the intake and wrap the filter with a clean rag, this should absorb the oil. Then clean the inside of your throttle body with a t/b spray cleaner.
Old Jul 9, 2003 | 12:08 PM
Default Re: Cleaned Filter (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">yeah, sounds like you might have put too much oil on the filter. however, it should improve over the next couple of days. once the carrier evaporates and only the oil is left, the filter should be breathing as it once did. no need to buy another filter.
did you let the filter air dry before reoiling?</TD></TR></TABLE>
yep
Old Jul 9, 2003 | 12:51 PM
nerdish's Avatar
Does anyone want to take a K&N Filter cleaning kit off my hands? I used it once and don't have a need for it anymore. Both bottles are almost full.
Old Jul 9, 2003 | 01:37 PM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">Possibly, is there a way I can take some of the oil off? Will it hurt anything having too much oil on it? </TD></TR></TABLE>
The problem I had long time ago when I was in college with a 87 Civic Si were I cleaned the K&N filter too often and oil build up thru the years onto the THROTTLE BODY's plate so my ideling got to be real erratic. I pull off the intake hose and saw that! I sprayed Throttle body cleaner and DAMM, Idel shot up and what a different in response. Try that for youself.
Adankid
Jan 1, 2009 03:12 PM
Budget Racer
Nov 24, 2006 01:07 AM
non-VTEC
Mar 27, 2003 06:41 PM
dz
Feb 25, 2002 05:51 PM
Phat Corolla
Jun 27, 2001 04:04 PM
