Clutch engaugment problem
Old Jul 9, 2003 | 01:57 AM
89dxhunchback's Avatar
Default Clutch engaugment problem
I swapped a D16Z6 into my civic, and I didn't have a clutch alinment tool or a new throw out bearing at 2:30am...
I can **** the tranny with the engine running ( and of course it doesn't move ). It will shift with the clutch pushed in or out ( like the clutch is always pushed in ). If I put it in 4th gear the rpms drop about 2-300 rpms, but it doesn't even move the car at all. I've tried adjusting the cable on the tranny and I can feel the difference in pedal when I adjust it, but no matter where I put the adjuster, the car still doesn't move.
DX tranny, D16D6 clutch and flywheel.
Old Jul 9, 2003 | 05:22 AM
REDBARON's Avatar
Default Re: Clutch engaugment problem (89dxhunchback)
Let me get this straight.
You can shift the tranny while the engine is on, whether you step on the clutch pedal or not, and the car will not move, even if you have it in gear, and release the clutch pedal, right?
Old Jul 9, 2003 | 05:53 AM
Default Re: Clutch engaugment problem (REDBARON)
yep... motor runs with 8.4/1 compression, but not with the same tranny I'm had for the last 1 1/2... Kinda wanted to see how much power I lost..
Old Jul 9, 2003 | 06:04 AM
REDBARON's Avatar
When you re-installed the used throwout bearing, did you install the spring on it correctly?
Old Jul 9, 2003 | 07:27 AM
to be honest I didn't do the clutch part of my swap ( nice huh.. ) I was swapping the Intakes while a friend was doing the clutch part.
Old Jul 9, 2003 | 08:07 AM
REDBARON's Avatar
Honestly, it sounds like that's your problem. I'd double check that it was done correctly. While your at it, get a new T/O bearing and spring.
Old Jul 9, 2003 | 09:31 AM
streetlegal gocart's Avatar
First of all find a friend that KNOWS how to replace a clutch. J/p, but seriously, have someone whos sure rip it apart and recheck it.
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
bradennicely
Apr 23, 2010 07:37 AM
tony88crx
Jun 21, 2005 06:37 PM
CimorelliCRX
Dec 15, 2002 04:02 AM
