10psi o.k. for stock b16?
I just got my turbo going on my b16 and it seems the wastegate is set to 10psi. I was planning on running 8psi but if 10psi won't blow up anything I don't see what the problem is. I'm running larger injectors with the v-afc hack and a t-3 turbo on a stock block.
Make sure you get it tuned and you'll be fine.
I blew mine up after a week on 10psi....then again i didnt know **** about turbo's back then.
