would these add on help???
Old Jul 8, 2003 | 11:54 PM
tangb2023
Guest
Posts: n/a
Default would these add on help???
freind gave me a gsr gurdle, gsr oilpan and pickup.. along with gsr thermostat housing with extended housing pipe to the rear of the engine.. would this help out a b20b ??if so how??
Old Jul 9, 2003 | 12:16 AM
built562's Avatar
Default Re: would these add on help??? (tangb2023)
the block gridle (sp) will only work with the main caps and bolts from a gsr, it hols the bottom end tighter together at high rpm and the gsr oil pan an pick up is needed for this upgrade. definantly worth putting in. as for the thermostat housing onluy if its the one with the oil cooler, if not i think its the same as a b20
Old Jul 9, 2003 | 03:32 PM
tangb2023
Guest
Posts: n/a
Default Re: would these add on help??? (akumaracer)
how would the oil pan and pickup help?
Old Jul 9, 2003 | 03:49 PM
built562's Avatar
you need the oil pan to clear the block gridle, if you put the gridle on the b20 oil pan will clear it
feriotypeR
Feb 10, 2010 01:10 PM
The Si
Feb 17, 2007 04:11 PM
SiR831
15
May 3, 2005 07:44 PM
hovic
Feb 12, 2004 08:55 AM
88CRXHybrid
Mar 17, 2002 07:15 PM
