would these add on help???
Re: would these add on help??? (tangb2023)
the block gridle (sp) will only work with the main caps and bolts from a gsr, it hols the bottom end tighter together at high rpm and the gsr oil pan an pick up is needed for this upgrade. definantly worth putting in. as for the thermostat housing onluy if its the one with the oil cooler, if not i think its the same as a b20
you need the oil pan to clear the block gridle, if you put the gridle on the b20 oil pan will clear it
SiR831
15
05-03-2005 07:44 PM
hovic
02-12-2004 08:55 AM
88CRXHybrid
03-17-2002 07:15 PM
