Type R cam install
Whats up, I need some help with my Type R cam install in my 97 GSR. I'm putting them in this weekend. Is there anything I need to adjust. I'm not getting cam gears installed right now. So other than that is there anything I need to adjust?
thanks,
thanks,
Just keep track of the timing belt and keep everything at TDC. Being one tooth off will throw the whole motor out of sync. make sure you do a valve adjustment right after the install as well and dont forget to use plenty of assembly lube and use correct torque specs.
Soccerking3000
24
May 14, 2004 08:30 AM
DumpedSi
Jul 28, 2003 07:26 PM
