how to bleed brake master cylinder?
Old Jul 8, 2003 | 01:18 PM
miataguy's Avatar
Default how to bleed brake master cylinder?
I've bleed my brakes over 10 times and replaced the calipers but the brakes are still very mushy and the pedal goes down to the floor. A shop that I just got my car aligned at suggested the master cylinder might need to be bled. What is required to do this? I've read of a "bench bleeding kit" but where would I buy one of those?
Old Jul 8, 2003 | 03:04 PM
martilafox's Avatar
New User
It doesn't need to be bled, you need to replace the it. Sorry to give you the bad news, but you won't regret it.
Old Jul 8, 2003 | 09:00 PM
EKFerioHawaii's Avatar
Default Re: how to bleed brake master cylinder? (miataguy)
Most rebuilt master cylinder kits come with a bench
bleed kit. If not, I bought a few for, at the most, $10.
To bench bleed you need to connect the bleeding kit
to the master cylinder. Then securely place the master cylinder
in a benchvise. Fill the master cylinder with brake fluid.
Run all the plastic lines from the bleeding kit into the
resovior. With a piece of wood, push on the master cylinder
rod gently back and forth until there are no bubbles in the
resovior.
Some tips I learned:
If you don't have a benchvise, have some one hold the master
cylinder while you pump it.
Tap the resovior lightly as to surface all air bubbles that may
be trapped in all crevices.
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
mattbatson
Oct 23, 2008 07:30 PM
yz125rider21
20
Mar 4, 2007 12:58 PM
integra123
Aug 8, 2006 05:52 PM
Doctor CorteZ
26
Oct 23, 2002 11:28 AM
