Terrible numbers on dyno......can anyone give me an answer!!!!!!!
Old Jul 8, 2003 | 09:29 AM
HYPE TYPE's Avatar
Default Terrible numbers on dyno......can anyone give me an answer!!!!!!!
Setup:
00 Type R
JRSC @6 psi
dc header
330 injectors
aem fuel rail
hondata stage 2b
Timming set @ 22 degrees,
AFR anywhere from 11.8- 12
Now I've heard of similar setups where guys were getting 230 whpr, I wasn't even hitting my stock numbers.....I was around the 160-165 mark......I dont know what F**K is up ... can anyone help point me in the right direction!!
Old Jul 8, 2003 | 09:38 AM
quikB18B's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (HYPE TYPE)
That looks like stock #'s, You sure the Dyno wasn't messed up. I dont know what to tell you, who tuned it?
Old Jul 8, 2003 | 09:41 AM
HYPE TYPE's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (quikB18B)
I got it tunned by the only guy who is liscensed in ontario to sell and tune hondata.....all I know is he took maybe 30 minutes to tune the top end, from 6500-8500!
Old Jul 8, 2003 | 09:42 AM
quikB18B's Avatar
i would take it back to him tell him to find and fix the problem.
Old Jul 8, 2003 | 09:50 AM
HYPE TYPE's Avatar
see he wants to take it to another dyno...charge me another 200 bucks.....and see what numbers it can put out on that dyno.....but it might read say 10 hpr higher...but the car does not feel like it has 220@ the wheels that's for sure!
Old Jul 8, 2003 | 10:14 AM
Overblown-Teg's Avatar
Its not the guy tuning the cars fault if its not making power.. It could be anything that is wrong..
Old Jul 8, 2003 | 10:23 AM
JM Performance's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (Overblown-Teg)
compression?
Old Jul 8, 2003 | 10:24 AM
MooreBoost's Avatar
Do you have I/E? If you dont, thats holding you back aton. Also, get the 8 pound pulley, that will help alot also, but I wouldnt do that until you find this problem. Your timing is awfully high isnt it? I only have mine at +2 degrees. What is your fuel psi?
gmoore
Old Jul 8, 2003 | 10:27 AM
DC2R714's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (00SilverLS)
Same thing happened to my car. I was putting down like stock numbers. Turned out I had cracked ringlands, rings, cracked pistons. It was a mess. Do a leakdown and compression test to find out whats going on inside.
Old Jul 8, 2003 | 10:45 AM
b16ahybrid's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to my car. I was putting down like stock numbers. Turned out I had cracked ringlands, rings, cracked pistons. It was a mess. Do a leakdown and compression test to find out whats going on inside.</TD></TR></TABLE>
do that before you invest in more tuning, That way you know your engine is mechanically sound
Old Jul 8, 2003 | 11:44 AM
i2un's Avatar
330 injectors and hondata?
Old Jul 8, 2003 | 12:51 PM
Andrew 825SM's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (i2un)
Do a dry and wet compression test first and tell us the results.
Old Jul 8, 2003 | 01:02 PM
FrcdFedGsr's Avatar
It could be your timing or the dyno wasn't calibrated right, i suggest you take it back to the person or have it tuend by a liscensed professional from hondata
Old Jul 8, 2003 | 01:15 PM
2BAR4ME's Avatar
I would agree with going for the compression test. Sounds like something is wrong inside, but who knows. I would go to the guy that tuned it and make him re-do it for free. It doesnt take a genious to figure out that you should be putting down way more than that. My buddy with a JRSC on a SOHC Civic put down 159 with the stock pully and tuing, you should for sure be getting over 200.
My $0.02, Good luck
Old Jul 8, 2003 | 01:25 PM
paulzy's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (2BAR4ME)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2BAR4ME &raquo;</TD></TR><TR><TD CLASS="quote">I would agree with going for the compression test. Sounds like something is wrong inside, but who knows. I would go to the guy that tuned it and make him re-do it for free. It doesnt take a genious to figure out that you should be putting down way more than that. My buddy with a JRSC on a SOHC Civic put down 159 with the stock pully and tuing, you should for sure be getting over 200.
My $0.02, Good luck </TD></TR></TABLE>
that's not right, for all we know, he pulled baselines or like 130hp
Old Jul 8, 2003 | 02:06 PM
ekb18c's Avatar
What was your baseline run??
You can't blame the tuner right away. There are so many different variables that can come into play.
If for instance, you did a base line run and made 120whp. Then the tuner did his job by getting you 170whp with your setup..
If however your baseline run was 169whp and he got you 170whp then that's different story.
Old Jul 8, 2003 | 04:13 PM
11psiTurboSI's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (ekb18c)
I say do a compression check... might be a ringland or ring or you belt might have been slipping and you didn't know it is a another suggestion.
Old Jul 8, 2003 | 04:25 PM
ClubSiRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYPE TYPE &raquo;</TD></TR><TR><TD CLASS="quote">
Now I've heard of similar setups where guys were getting 230 whpr, I wasn't even hitting my stock numbers.....I was around the 160-165 mark......I dont know what F**K is up ... can anyone help point me in the right direction!!</TD></TR></TABLE>
First of all, the people making 200+whp with a JRSC are the people who also put a LOT more work and tuning into their setups. They are the "above average". Most are also running well over the base 6psi boost setting, usualy 8-10psi.
It sounds to me like you need to hook up a wideband O2 while on the dyno and get some accurate A/F's plot with your revs and tune from there. Also how much ignition retard did you dial in, and how?
Old Jul 8, 2003 | 04:46 PM
b18cTurbo's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (ClubSiRacer)
can you show the dyno graph?you sure your vtec working ?
Old Jul 8, 2003 | 05:51 PM
bottlefedb18c1's Avatar
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (Andrew 825SM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">Do a dry and wet compression test first and tell us the results.</TD></TR></TABLE>
what is your deffanition on a wet test what do you use and how much of it?
Old Jul 8, 2003 | 06:29 PM
Default Re: Terrible numbers on dyno......can anyone give me an answer!!!!!!! (bottlefedb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
what is your deffanition on a wet test what do you use and how much of it?</TD></TR></TABLE>
Put like a tablespoon or two of oil in ur cylinder when you do a compression check. If it rises 30 psi or more above your normal readings, your rings might be shot. This is because oil creates a better seal for the piston.
Old Jul 9, 2003 | 12:04 PM
i2un's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i2un &raquo;</TD></TR><TR><TD CLASS="quote">330 injectors and hondata?</TD></TR></TABLE>
I'm assuming your base map was shitty since most people have 440's and Hondata.
Without a decent basemap to work with or excellent tuning by your tuner I'd expect low numbers.
P.S. What was the torque?
HYREV2NR
Sep 4, 2022 11:01 AM
Navy_CRX
Engine Management and Tuning
Mar 6, 2009 09:45 PM
ek9800
May 11, 2005 11:24 AM
builtprelude
15
Feb 12, 2004 10:50 AM
Hondata
Apr 12, 2002 01:55 PM
