b18 gsr not running right
Old Jul 8, 2003 | 07:47 AM
eg6hatch's Avatar
Default b18 gsr not running right
hi, i am almost done with my b18c gsr swap, im just waiting on a few parts, well anyway, the motor is at a point now, where it can be started, just not on the ground rolling yet, well i dont have my o2 sensor hooked up, or my knock sensor, but my friend did a b16a, and started his before he had those things hooked up, and his ran fine, mine doesnt, it ran for like 3 min, then died, now you try to start it and it dies right away. well, i have a vafc, and its not showing any throttle position, well we think it might have soemthign to do with the throttle somehwere, whether it be throttle position sensor, or something else, does anyone have any ideas. thanks
Old Jul 8, 2003 | 07:54 AM
B_CRUZ!'s Avatar
Default Re: b18 gsr not running right (eg6hatch)
you should of got the swap up and running first then install the VAFC. Now its just more of a bitch to trouble shoot. You may have switched the plugs on the tps and map. Also hook up all of the sensors before you assume anything.
Old Jul 8, 2003 | 09:22 AM
eg6hatch's Avatar
Default Re: b18 gsr not running right (B.CRUZ)
well i already had teh vafc hooked up to my factory 94 civic si motor, so when we plugged the ecu in, we figured everything would be cool, and yes all teh sensors are hooked up, for sure
low-tech assassin
Nov 6, 2003 10:43 PM
Black R
Jan 22, 2003 02:20 PM
Mr. Vapor
Mar 23, 2002 06:11 AM
S&P500ITR
Dec 8, 2001 05:51 PM
