missed a gear, possible underlying problems?
i was redlining 2nd gear last night and i missed 3rd. my rpm went to about 9.5k. my head is fully build with skunk2 stuff including high compression valves springs and ti. ret. i did a compression test and cyl. 1, 2, 4 were at 210 and 3 was at 195. seems ok to me and maybe i got lucky. the thing is my battery light came on and it wont go out. is this a sign of a major problem? what could be causing that? thanks guys
no, it didnt go into any gear. i was shifting into 3rd and let the clutch out to soon and the car never went into third. i didnt mis-shift, just missed the gear entirely
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR »</TD></TR><TR><TD CLASS="quote">dude Andy, you're always phuckin' that car up
I think it'll be fine.</TD></TR></TABLE>
no ****, at least the compression test was ok, so i didnt *** up the valves, man this sux
thats what i would think, unless ecu doesn't have rev limiter..
whenever i missed gear, it would always hit rev limiter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">then your rev-limiter should have saved you.</TD></TR></TABLE>
this retarded ecu that my roomate gave my doesnt have a rev-limiter as far as i know
any other thoughts on the battery light?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t »</TD></TR><TR><TD CLASS="quote">9500rpm is not high. Check your alt. belt.</TD></TR></TABLE>
yea the belt is totally gone, not even on the car anymore. so i was going to change it today, but i seem to be having trouble getting the nut off the bottom of the alternator so i can rotate it and get the belt on. any ideas on how to make this job easier?
WeaponR
May 25, 2004 04:14 PM
