pcv valve?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt »</TD></TR><TR><TD CLASS="quote">wow hardcore! You still use a honda oil filter? hell yah! I am going to check into both of these points thanx.
Oem oil filter or Mobil 1. I dare not use fram or other filters.
Of course you will have oil coming out of your beather, it is only paper thin and designed for filtering oxygen, not oil. So in your case, oil will seep through. I would recommend connecting your intake to your valve cover breather.
The PCV valve does not effect the amount of oil that will come out the beather, technicaly. However, just in case, to check your PCV valve, take it out and shake up and down, if it does not click, replace it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic »</TD></TR><TR><TD CLASS="quote">here is myne of a d16y8, should be in similar location on b-series too
</TD></TR></TABLE>are you sure thats your pcv valve? the pcv valve is a small elbow shaped piece on the inatke manifold.
its number 6 in the link picture.
http://www.hondaautomotivepart...EC%29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Of course you will have oil coming out of your beather, it is only paper thin and designed for filtering oxygen, not oil. So in your case, oil will seep through. I would recommend connecting your intake to your valve cover breather.
The PCV valve does not effect the amount of oil that will come out the beather, technicaly. However, just in case, to check your PCV valve, take it out and shake up and down, if it does not click, replace it!</TD></TR></TABLE>
I would, but I dont think that would work well with the charge pipe on my turbo kit.
yes that is the pcv valve. on the gs-r motors it is directly on the black box like how its pictured above. for the other motors is is held on the intake manifold but the hose is connected to the same spot.
lowgman
Apr 21, 2004 04:14 PM
