2 questions. air/fuel and fuel pump
Old Jul 29, 2001 | 09:07 PM
5gen-hybrid's Avatar
New User
Default 2 questions. air/fuel and fuel pump
today i installed my holly 255lph fuel pump in my civic. everything went smoothly until i tried to start the car it wouldn't crank over (no fuel). so i went back and double checked everything. all conections were good??? i know the was signal going to it because it was warm from trying to start the car but when i pulled the hose off the pump there was no fuel pressure or fuel in the hose??? i also double checked the polarity and that was good any idea's anybody have problems with these pumps(i know most people here like the bosch pumps) also if i return it should i get the f/i pump whats the difference??
then here is my second question after that misshap i figured that i should get something accoplished so i hooked up my air/fuel gauge. everything is hooked up and i think it's working (i have not driven my car yet) but when i start it the first two lines light up then go away and none are lit up when it is idleing but if i rev it a little they light up (is this normal how will i know where my air/fuel is at idle?)it is an autometer air/fuel ratio gauge. thanks any help is greatly appreciated
jesse
Old Jul 29, 2001 | 09:21 PM
TurboInteg95's Avatar
Default Re: 2 questions. air/fuel and fuel pump (hybridxcivic)
you have to have the FI version of the pump. the one youre using cant support the high fuel pressures. Also, the problem youre having with your A/F gauge is the same one I had. I ended up just putting another O2 sensor on my downpipe and using that one to run my A/F gauge. For some reason it wasnt working correctly off of the stock 4-wire sensor.
Old Jul 29, 2001 | 09:46 PM
GSRwBOOST's Avatar
Do you have the correct wire tapped? I had a similar problem and found out i was tapped into the wrong wire.. the correct one i belive is white, the big one??
Not usre on the pump, it should have enough fuel to start your car, the pump has no idea if your FI or not, so it should at least give you fuel to start the car... the FI seems logical but doesnt explain why you dont have ANY fuel going through..
got gas?
Old Jul 29, 2001 | 09:54 PM
New User
Default Re: 2 questions. air/fuel and fuel pump (GSRwBOOST)
yeah i believe that i have the rite one i taped into it at the ecu a white one on the 16 prong plug (thats the one my mechanic told me it was the plug for my o2 sensor is hidden under my intake manifold so it is a bitch to get to) maybe i'll try using another o2 sensor thanks i guess i'll send the pump back to summit racing and tell them it doesn't work then i'll have them send my the f/i one. how high will they flow my stock one craps out at 85 psi or so.also what do you guys run your timing at (assuming that you still use your stock ecu) i was told to fun it at 12 or 14 degrees and not a full 16 degrees. thanks
Old Jul 29, 2001 | 09:55 PM
New User
Default Re: 2 questions. air/fuel and fuel pump (TurboInteg95)
oh and yeah i do have gas well some enough for the stock one to work
Old Jul 29, 2001 | 10:13 PM
VaporTrail's Avatar
New User
Check the fuse for the fuel pump (can't remember which it is). I had this problem, had to up the fuse from 10amp to a 15amp fuse.
Old Jul 29, 2001 | 10:16 PM
New User
Default Re: 2 questions. air/fuel and fuel pump (VaporTrail)
but i put the stock one back in and it works??? so it can't be the fuse.
Old Jul 29, 2001 | 10:19 PM
dustin's Avatar
Maybe the pump is just broken.
Get a multimeter and test for continuity across the terminals of the pump.
Dustin
Old Jul 29, 2001 | 10:24 PM
New User
Default Re: 2 questions. air/fuel and fuel pump (dustin)
that is what i'm hopeing because i guess i need the one for f/i. anybody know the part #. it almost seems like it is jammed or something because it gets really hot or it's grounding out inside??
Old Jul 29, 2001 | 10:37 PM
dustin's Avatar
I would definately get another one, it should not get hot.
Dustin
4doorcivic9
Jun 11, 2008 06:31 AM
deerek101
Aug 31, 2007 08:53 AM
O16581724 5 2 5
Jul 6, 2006 06:45 AM
tuan...
Aug 5, 2004 03:10 PM
DC_andrew
Jul 11, 2004 07:57 PM
