EG with H22 motor will stock ac fit, if I buy a bracket?
Old Jul 7, 2003 | 09:26 PM
Trbospnkr's Avatar
Default EG with H22 motor will stock ac fit, if I buy a bracket?
I have an EG with an H22 motor, I'm in the process of installing the stock air conditioning system in my car. I was told that I needed to buy a bracket to fit the condensor, will the ac radiator fit?. Because when I tried putting it in, the alternator was in the way. Would I have to buy an after market fan to make it fit?, please help in anyway.
Old Jul 7, 2003 | 09:31 PM
Newman's Avatar
New User
Default Re: EG with H22 motor will stock ac fit, if I buy a bracket? (Trbospnkr)
HCP is the only company right now that makes the AC bracket for the H22 swap in a 92+ Civic, allowing you to bolt your existing Civic AC compressor to the bracket. Clears the alternator just fine. On an EG, you'll need to use a pusher fan in the front of the AC condensor as fitment is very tight, but well worth it when it's all working in the summer.
mikeledez
Jun 16, 2010 08:03 AM
b18tegg
Oct 29, 2006 03:14 PM
slowsleeper
Jun 6, 2006 06:54 AM
bigxclumzy
May 19, 2006 03:40 PM
