Block Guard vs Sleeves
Old Jul 7, 2003 | 07:53 PM
SRL's Avatar
SRL
Default Block Guard vs Sleeves
can i use block guard instead of the sleeving the block? would block guard be safe enough for 10-15psi?
Old Jul 7, 2003 | 08:30 PM
B18PoweredCivic's Avatar
Default Re: Block Guard vs Sleeves (1KleanTeg)
any motor sleeved or not, blockguarded or not, will not last unless tuned properly...Ive seen cars running stock bottome ends boosting 15psi with no problem but tuned properly...And ive seen blown motors that had aftermarket sleeves only boosting 12 psi...I personally run a blockgurad on my GSRbottomend and hold 12 psi fine...but tuned properly...If you have the money to get the sleeves..Do it..But a bloackguard will hold up fine...Friend of mine ran 18psi on stock bottom end with a blockguard...But just remember that tuning is the key...So if money is tight and sleeves cant be purchased...A bloackguard will work fine...
Old Jul 8, 2003 | 04:50 AM
SRL's Avatar
SRL
Default Re: Block Guard vs Sleeves (B18PoweredCivic)
so block guard will be fine with properly tuned...that's all im wondering, thanks for the infos, and yet, 12psi is so f*cking damn sweettt... are u running with hondata s2, EMS or VAFC? mind tellin me what boost kit ur using and how much it puts out?
Old Jul 8, 2003 | 05:44 AM
YEP..Hondata s200...I havent even had it Dyno tuned...Just street tuned and car does 12.8 on street tires and pump gas...Im using a custom Kit I built with a Drag manifold and t3/t4 turbo
Old Jul 9, 2003 | 09:28 PM
SRL's Avatar
SRL
Default Re: (B18PoweredCivic)
damn...i'd be hella happy to be in the 12s...good job on that monster, btw, ur running on pump gas, which is 91 octane? that's gangsterr man...
Old Jul 9, 2003 | 11:05 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (1KleanTeg)
the blown motors you have seen with sleeves did not split a sleeve though liek blown motors with stock sleeves. yes they can both blow but the right way to do it with peace of mind is to sleeve the block. you will not split an iron sleeve like you will a stock one.
Old Jul 10, 2003 | 07:50 AM
93 octane from sunoco
Old Jul 10, 2003 | 07:55 AM
pissedoffsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18PoweredCivic &raquo;</TD></TR><TR><TD CLASS="quote">I havent even had it Dyno tuned...</TD></TR></TABLE>
and THAT'S how you blow up
Old Jul 10, 2003 | 08:47 AM
Default Re: (pissedoffsol)
Thats why she's sitting in the driveway...Snzzzzzzzz....Snzzzzzzzz...Sleeping ..Sorry but I was in a rush to run her...Boost is addicting...I cant just watch her sit there till she gets dyno tuned j/k
Sgtschif
Dec 29, 2013 01:12 AM
TurboB16A300Hpteg
Feb 3, 2008 08:39 AM
marksturboek
Apr 23, 2006 03:02 PM
madman604
May 23, 2003 04:19 PM
sleepercivic
Sep 11, 2002 08:12 AM
