will H series throttle body fit on d16y8 without a problem?
Old Jul 7, 2003 | 06:44 PM
civicmatt's Avatar
Default will H series throttle body fit on d16y8 without a problem?
Is this as simple as a bolt on deal? Will the throttle rotor rotate the right direction? How will the sensors match up? Thanks.
Old Jul 8, 2003 | 04:00 AM
civicmatt's Avatar
Default Re: will H series throttle body fit on d16y8 without a problem? (civicmatt)
I did a search, but didn't find an answer.
Old Jul 8, 2003 | 04:53 AM
TheAutoboxer
Guest
Posts: n/a
hmm.. the b series bolt on without problems.. but h series.. well i'm gonna guess so.. free dump
Old Jul 8, 2003 | 12:07 PM
civicmatt's Avatar
Default Re: will H series throttle body fit on d16y8 without a problem? (sedan)
Can anyone confirm or deny this?
Old Jul 8, 2003 | 12:09 PM
JaeOne3345's Avatar
it will work but u need to port match the d16y8 intake manifold. use a h22 TB gasket.
Old Jul 8, 2003 | 01:57 PM
RyanEJ8's Avatar
Default Re: will H series throttle body fit on d16y8 without a problem? (JaeOne3345)
Yes, if you don't port match the intake manifold you won't see hardly any gains. The bigger throttle body and port matched intake will provide only a small hp gain, the major gain from doing this is the increase in throttle response.
Old Jul 9, 2003 | 04:56 AM
civicmatt's Avatar
Default Re: will H series throttle body fit on d16y8 without a problem? (RyanCivic2000)
I'm not looking for a monster HP gain. I'm going for throttle response. Will an h22 TB from a 97 prelude fit? Are all h22 TBs the same? I know nothing about preludes. Thanks.
Old Jul 9, 2003 | 05:14 AM
JaeOne3345's Avatar
we just said it will fit, but port match the intake manifold opening to the TB opening, or else its a waste of time. the two diameters are totally off.
Old Jul 9, 2003 | 12:52 PM
civicmatt's Avatar
Thanks.
Old Jul 9, 2003 | 01:11 PM
SOHC_MShue's Avatar
do you have to port match for a b-series throttle body?
Old Jul 9, 2003 | 03:26 PM
RyanEJ8's Avatar
Default Re: will H series throttle body fit on d16y8 without a problem? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">do you have to port match for a b-series throttle body?</TD></TR></TABLE>
Yes. It's the same concept. With just a bigger throttle body it won't do anything because the intake manifold won't be able to flow as well. You must port match.
Old Jul 9, 2003 | 06:40 PM
IDriveHonda's Avatar
Observe that the map sensor is located on the Y8 TB, make sure that the H22 TB is set up the same way.
ExtraBlackRex
Dec 5, 2010 09:34 AM
ge_ej1
Dec 27, 2007 12:20 AM
germanEE8
Feb 25, 2004 01:56 AM
SOHC_power
Apr 16, 2003 01:36 PM
cajnatc
Mar 3, 2003 10:10 PM
