will H series throttle body fit on d16y8 without a problem?
Is this as simple as a bolt on deal? Will the throttle rotor rotate the right direction? How will the sensors match up? Thanks.
Re: will H series throttle body fit on d16y8 without a problem? (civicmatt)
I did a search, but didn't find an answer.
hmm.. the b series bolt on without problems.. but h series.. well i'm gonna guess so.. free dump
Re: will H series throttle body fit on d16y8 without a problem? (sedan)
Can anyone confirm or deny this?
it will work but u need to port match the d16y8 intake manifold. use a h22 TB gasket.
Re: will H series throttle body fit on d16y8 without a problem? (JaeOne3345)
Yes, if you don't port match the intake manifold you won't see hardly any gains. The bigger throttle body and port matched intake will provide only a small hp gain, the major gain from doing this is the increase in throttle response.
Re: will H series throttle body fit on d16y8 without a problem? (RyanCivic2000)
I'm not looking for a monster HP gain. I'm going for throttle response. Will an h22 TB from a 97 prelude fit? Are all h22 TBs the same? I know nothing about preludes. Thanks.
we just said it will fit, but port match the intake manifold opening to the TB opening, or else its a waste of time. the two diameters are totally off.
Thanks.
do you have to port match for a b-series throttle body?
Re: will H series throttle body fit on d16y8 without a problem? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">do you have to port match for a b-series throttle body?</TD></TR></TABLE>
Yes. It's the same concept. With just a bigger throttle body it won't do anything because the intake manifold won't be able to flow as well. You must port match. |
Observe that the map sensor is located on the Y8 TB, make sure that the H22 TB is set up the same way.
