sway bar?
Old Jul 7, 2003 | 05:50 PM
bonta-kun's Avatar
Default sway bar?
hey i was juss wondering what kind of sway bars i should get for my 93 dx coupe and what size would be good...also do i need to change anything else to put them on or is it bolt on tia...
Old Jul 7, 2003 | 05:52 PM
STIBungy's Avatar
You could put on a GSR sway or get some aftermarket ones. However, you'll need to get different lower control arms that have threads for the endlinks. GSR lower control arms would work.
Old Jul 7, 2003 | 05:58 PM
B16b2b's Avatar
Default Re: sway bar? (oneslowej)
another well-searched question about swaybars.......
Old Jul 7, 2003 | 06:06 PM
elwood's Avatar
Default Re: sway bar? (B16b2b)
If you want to go with the oem honda swaybars then you will
need new control arms. Let me go find an old post of mine.
edit- I hate the search. I cant find a damn thing on there.
You will need to get control arms from:
front:
94+ integra
92-95 si/ex civic
(dont know my years) del sol
rear:
94+ integra
92-95 ex sedan
del sol dohc
Rear Swaybar sizes:
94+ integra lower models 13mm
94+ integra gsr 14mm
92-95 civic ex 4dr 13mm
Del sol I think its a 13mm
Front Swaybar sizes:
94+ integra lower models (i think) 19mm
94+ integra gsr 24mm
92-95 civic ex 4dr 19mm
Del sol I think its a 19mm
I hope that helps out some.
Modified by d15dude at 11:25 AM 7/8/2003
Old Jul 7, 2003 | 06:32 PM
turkdog's Avatar
get gsr LCA and put the 22mm type - r sway bar on.
Old Jul 7, 2003 | 07:35 PM
Harpua's Avatar
Default Re: sway bar? (d15dude)
DOHC Del Sol Rear Bar is 15 mm (stock)
Old Jul 7, 2003 | 07:39 PM
elwood's Avatar
Default Re: sway bar? (Harpua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harpua &raquo;</TD></TR><TR><TD CLASS="quote">DOHC Del Sol Rear Bar is 15 mm (stock)</TD></TR></TABLE>
Are you sure?
A great way to check is to use an open end metric wrench.
99hondacura
Suspension & Brakes
Jun 28, 2008 08:47 PM
dj theoretic
Apr 15, 2008 04:50 PM
4potnick
Jul 10, 2006 12:09 PM
CRXdan
Mar 4, 2006 06:43 PM
92civic_eg
May 17, 2004 02:56 PM
