car dont start
whats up
90 crx si still got d16a6 in it
started fine, went to school-came back, car doesnt start. no codes
doesnt even crank over.
had to push start it, ran fine, turned it off wouldnt start up.
thought starter was bad, took it to autozone, checked out ok
my lights and radio work fine, i havent tested it yet, but the battery seems fine, fairly new.
i was thinking it could be the igniton switch, or maybe possilby a short in the wiring
just looking for some ideas, if this has happend to anyone?
thanx
Modified by B pwr at 10:05 PM 7/7/2003
thanx
yep thanx evryone
checked it earlier in the day, grounds, battery starter, all good.
still the same though.
im wondering about that clutch interlock switch on the clutch pedal, i just picked up my helms a little earlier, ill check it in the morning
ok found it.
un top of clutch pedal, theres is blue rubber grommet, just like on the brake pedal/ switch.
if its broke or fell out, car will not start, its needed to push the plunger on the clutch interlock switch, to start the car.
in my case it fell out(deteriated).
solution. 10mm bolt/nut. works perfect.
thanx
thanx
