mixing and matching cams and valvetrain
Old Jul 7, 2003 | 10:14 AM
letholone's Avatar
Default mixing and matching cams and valvetrain
anyone ever have any problems they can honestly say it was becuase of the mixing or matching of parts when doing this?
my thinking is that there is no differance in the springs and retainers ment to run skunk stage 2 or 3 cams.
and since the stage 3 skunk is biger in lift then the JUN 3's. there logicly be no problems there either.
anyone care to share some thoughts on this topic of mix-matching???
Old Jul 7, 2003 | 05:18 PM
granada_sun's Avatar
every valve train component has its limits as far as how high the RPMS climb, but mixing and matching isn't a problem, as long as the parts are for the head, which every b-series head component is the same, so there shouldn't be any problems if installed correctly. Hope this helps.
Old Jul 7, 2003 | 06:09 PM
AllMoToRB18c's Avatar
Default Re: (granada_sun)
as far as valve train goes for b-series it should all be the same...but i heard that u cant cant miss match the cam covers....the covers that hold the cams into place.....has anyone else heard this b4?
Old Jul 7, 2003 | 06:20 PM
true....LS valve cover wont fit on vtec head...hmmmm
Old Jul 7, 2003 | 07:07 PM
HaUTSaauce's Avatar
New User
Default Re: mixing and matching cams and valvetrain (letholone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever have any problems they can honestly say it was becuase of the mixing or matching of parts when doing this?
anyone care to share some thoughts on this topic of mix-matching???</TD></TR></TABLE>
i was wondering the same thing today
Old Jul 7, 2003 | 08:57 PM
evilxkid's Avatar
Default Re: mixing and matching cams and valvetrain (HaUTSaauce)
as long as your cams don't have more lift than the springs can take. they'll bind and wreck your cams.
Old Jul 7, 2003 | 09:00 PM
MackSpeed-616's Avatar
Default Re: mixing and matching cams and valvetrain (evilxkid)
i run jun 3 cams
toda valvesprings
portflow retainers
stock itr valves
Old Jul 7, 2003 | 10:48 PM
soakit's Avatar
Default Re: mixing and matching cams and valvetrain (BustaNutt-616)
what made you go with the toda valvetrain?
Old Jul 7, 2003 | 11:47 PM
dude toda....the name says it all.....u know what mugen is right???
Old Jul 8, 2003 | 06:44 AM
letholone's Avatar
have some sense pal.
the title is mixing and matching cams and valvetrain.
soakit, and i for that matter, would like to know what made him CHOSE to use toda valvetrain over anything else.
such as,JUN....youve heard of them right.
JUN wants you to use their valvetrain with their cams, so why did you(busta) use toda.
did you find something better in the springs. stiffer, allow more lift??? or maybe you just had these sitting around?
i just wanna know what makes people use other valvetrain when there is a valvetrain designed for the cams they run??
Old Jul 8, 2003 | 07:26 AM
Drag R's Avatar
Default Re: (letholone)
Jun springs bind @ 12.0mm, Toda's can go as far as 12.9, maybe even more....
Todas are stiffer, probably one of the stiffest on the market.
install height has to be exact with jun springs....
Modified by Drag R at 12:09 PM 7/8/2003
Old Jul 8, 2003 | 07:43 AM
portflow makes some of the best head springs out there......check out the comparison chart....
http://www.importreview.com/re....html
Old Jul 8, 2003 | 08:05 AM
Drag R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">portflow makes some of the best head springs out there......check out the comparison chart....
http://www.importreview.com/re....html</TD></TR></TABLE>
Toda's take the cake!!!
Old Jul 8, 2003 | 12:49 PM
Default Re: (Drag R)
drag r said it
Old Jul 8, 2003 | 12:55 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R &raquo;</TD></TR><TR><TD CLASS="quote">
Toda's take the cake!!!</TD></TR></TABLE>
..and the bag of chip's!
Old Aug 21, 2003 | 09:47 PM
deebee-II's Avatar
did a search and found this,
my question is, has anyone mixed crower b series VTEC duel valve springs (part no. 68185) with toda spec b's or greater?
just wondering if anyone has had problems and at what rpm was your redline?
Old Aug 23, 2003 | 11:38 AM
alexboy's Avatar
Default Re: (deebee-II)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deebee-II &raquo;</TD></TR><TR><TD CLASS="quote">did a search and found this,
just wondering if anyone has had problems and at what rpm was your redline?</TD></TR></TABLE>
I have the exact same question or even can you run JUN springs with toda cams?
Old Aug 23, 2003 | 05:44 PM
alexboy's Avatar
Default Re: (alexboy)
anyone
Old Aug 23, 2003 | 07:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexboy &raquo;</TD></TR><TR><TD CLASS="quote">
I have the exact same question or even can you run JUN springs with toda cams?</TD></TR></TABLE>
why couldnt you be able to?
Old Aug 23, 2003 | 08:54 PM
alexboy's Avatar
the reason I ask is because i have a set of Crower springs and retainers with 150 miles on them and a set of jun springs with 15k on the ... since my JUN3 cam broke and i am in the process of builing a new motor i am tryin to be on the safe side and don't want to take the risk of losing my motor due to using incorrect valve springs
Old Aug 24, 2003 | 06:21 AM
b19coupe's Avatar
Go with Toda or Portflow springs if you are going to run big cams-i.e. 12mm of lift or more. Talk to Tom aka Portflow about your setup and see what he recommends. He was the person that helped Jeff with that valve spring test-BTW.
cleanep3
Jun 15, 2010 06:12 AM
underpressure02
Mar 10, 2006 06:07 AM
ekblacknight
Oct 25, 2005 05:46 PM
.honda.
Mar 22, 2003 05:03 PM
