How do you get the ground control sleeve off of a shock?
Old Jul 7, 2003 | 09:12 AM
drjondurst's Avatar
Default How do you get the ground control sleeve off of a shock?
I bought some used ground controls/ kyb agx's last year and one of my shocks recently blew. So I bought a new one. I just cant figure out how to get the threaded sleeve part off of the old blown shock so that I can put it onto the new shock. Any help is appreciated.
pic of the new shock.. I wouldnt think there should be anything tricky in doing this.
Old Jul 7, 2003 | 09:31 AM
bladesilver's Avatar
I'm kindn of confused. I have the exact same setup as you, and my sleeves are not attached to the shocks. Were they pushed on and became stuck because of the weight of the car, like its squeezed in there? or did the person who did them before you weld their sleeve on or something? The sleeve shouldn't be attached at all by anything. It even fits somewhat loosely onto the shock.
Old Jul 7, 2003 | 09:37 AM
keithv's Avatar
Default Re: (bladesilver)
the sleeve should just be sitting on the spring perch/collar. it shouldn't be too hard to remove...
Old Jul 7, 2003 | 09:40 AM
drjondurst's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bladesilver &raquo;</TD></TR><TR><TD CLASS="quote">I'm kindn of confused. I have the exact same setup as you, and my sleeves are not attached to the shocks. Were they pushed on and became stuck because of the weight of the car, like its squeezed in there? or did the person who did them before you weld their sleeve on or something? The sleeve shouldn't be attached at all by anything. It even fits somewhat loosely onto the shock.</TD></TR></TABLE>
Oh ok I didnt know that since I received the shocks/coilovers already assembled. Mine must've kinda squeezed itself onto the shock or something.. hammer and screwdriver should take care of that.
Old Jul 7, 2003 | 09:49 AM
Default Re: (drjondurst)
hmmm, well be careful. Basically the way it is assembled according to Ground Control's instructions is that there are 2 rubber O rings that go between the perch and the shock. All I can think is maybe they melted? But they should still be pliable. If the perch is really frozen in place, it is possible that the previous owner might have gotten creative and used some kind of adhesive to stick the perch in place
Old Jul 7, 2003 | 09:59 AM
drjondurst's Avatar
crap I hope I'll be able to re-use the two rubber O rings, im gonna go try this now
Old Jul 7, 2003 | 11:14 AM
drjondurst's Avatar
well the screwdriver + hammer idea worked. Those 2 black O rings were undamaged.. wasnt difficult at all.
Old Jul 7, 2003 | 03:00 PM
SiR Kid's Avatar
New User
I jsut swapped out my front shocks for 89 accord Tokico blues with the Ground Control sleeves... THe O rings expanded with wear and use, I guess, and mine were a PITA to get off, also. I just pulled hard, and off they came.
Old Jul 7, 2003 | 05:53 PM
eraser's Avatar
Default Re: How do you get the ground control sleeve off of a shock? (drjondurst)
just force it off
Old Jul 7, 2003 | 07:50 PM
kranked91dx's Avatar
He can't weld the sleeve on the shock, sleeve is in Aluminium and chock are in steel/stainless for the best of them, you can found damper in aluminium but shock are more often in steel
hope this help
Kranked
unsungfate
Oct 20, 2010 03:55 PM
lawlsss
Nov 30, 2009 11:47 PM
Ekfor
Suspension & Brakes
Mar 25, 2008 07:44 PM
mister_ej1
32
Mar 22, 2007 10:53 PM
Crank
Northern California (Sales)
Dec 29, 2006 02:11 PM
