when u got ur b16 in ur 90hb did they say....
Old Jul 6, 2003 | 07:11 PM
shadowstylz's Avatar
Default when u got ur b16 in ur 90hb did they say....
did they say the stock sir header wont match up w/ ur stock exhaust so u have to get header and exhaust before we can finish ur car?
Old Jul 6, 2003 | 07:21 PM
Racer613's Avatar
Default Re: when u got ur b16 in ur 90hb did they say.... (shadowstylz)
Nope...they said I was gonna have to run open header till I can get an exhaust built for my set up.... I didnt want to run the small *** garden hose exhaust anyway, not even temporary.
Old Jul 6, 2003 | 07:36 PM
ScottEK's Avatar
Default Re: when u got ur b16 in ur 90hb did they say.... (Racer613)
The flange on your cat will be flipped so it wont match up.
Old Jul 6, 2003 | 07:48 PM
91civicDXdude's Avatar
when i put my LS in, i put an HP 4-2-1 SS header in.. it was about 4 inches too long to bolt up to the exahust, the cat flange was rotated wrong, and the header was too angled. the shop had to heat and bend my downpipe and fix the exhaust so it would bolt to the header.
Old Jul 6, 2003 | 08:42 PM
b16_madman's Avatar
tell them to custom weld it up to your (whatever) kind of exhaust you have. I have a custom exhaust setup and they had to change it also when i got it, but nothing is too hard at a muffler shop. dont spend 500 or so on a catback if you don't want to
Old Jul 6, 2003 | 08:45 PM
ThatRicerDaniel's Avatar
usually i charge for this info but in a ls manifold you can use a d-series down pipe and it will bolt up.
Old Jul 7, 2003 | 06:12 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowstylz &raquo;</TD></TR><TR><TD CLASS="quote">did they say the stock sir header wont match up w/ ur stock exhaust so u have to get header and exhaust before we can finish ur car?</TD></TR></TABLE>
no because i did my swap my self, but when we got it all in we discovered that i would need a quick solution,
the solution is that if you have a 99-00 si b16a stock manifold lying around it will bolt up, since its a shop they should have one somewhere. if not buy a header,
Old Jul 7, 2003 | 10:05 AM
Malgerus's Avatar
Default Re: when u got ur b16 in ur 90hb did they say.... (slowpokesi)
I have an 88 STD hatch, and I flipped the stock cat so it would line up with my SiR downpipe... there was also about 3" of space between my downpipe flange and the front of my convertor, so I simply had someone push the muffler forward until I could get the bolts and springs attached to the flanges. These guys are just trying to tap you for more money. If you can't do the things I mentioned, any competent muffler shop can flip the cat and add an extension in the piping if it's too short, like mine was; I didn't bother. I saved for an exhaust, and it ran fine with the jury rigged stock system.
totsie7944
Oct 7, 2006 08:19 PM
JDM 007
Aug 6, 2003 11:15 AM
shadowstylz
Jul 4, 2003 09:43 PM
d_mina
May 16, 2003 06:16 AM
Lo-Buck EF
Jan 5, 2003 05:15 AM
