CRVTEC OIL PUMP
i have a crvtec in a 98 civic coupe and i think i need to get a better oil pump, i have a stock 2000 crv one in it now and im gettin ready to do a mild build with a vortech charger. does nebody have idea what oil pump i should use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek »</TD></TR><TR><TD CLASS="quote">The crv oil pump should have the same part number as a gsr which means it is the same part. </TD></TR></TABLE>
that is 100% CORRECT they are the same part
Wow, I learn something new everyday. BTW, All VTEC Oil Pumps have the same part number, even the ITRs use the same pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
Wow, I learn something new everyday. BTW, All VTEC Oil Pumps have the same part number, even the ITRs use the same pump.</TD></TR></TABLE>
that is correct as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">This is true for all new pumps. Older oil pumps weren't all the same. But I guess Honda finally thinks oil pressure is important now...
What year are you talking about when you say older oil pumps, i have a 96 crv block, which oil pump would i have and is it acceptable?? running a mild setup.
</TD></TR></TABLE>What year are you talking about when you say older oil pumps, i have a 96 crv block, which oil pump would i have and is it acceptable?? running a mild setup.
