All motor setup, want to run a little N20, is this safe?
Old Jul 6, 2003 | 10:04 AM
b16supertuner's Avatar
Default All motor setup, want to run a little N20, is this safe?
JDM ITR 11.4:1 with headgasket, PnP'ed head and IM, 70mm TB, Toda B's, Hondata, JDM ITR header or SMSP.
i want to run a 50 shot, Nx, would this be safe if i ran 110 octane, a Digi 6 plus retarding timing 2-3 degrees, and colder plugs?
Thanks
Old Jul 8, 2003 | 11:08 AM
2BAR4ME's Avatar
Default Re: All motor setup, want to run a little N20, is this safe? (b16supertuner)
I don't think you will have a problem. My buddy was squeezing a 120 shot on his Type-R with I,H,E. I was a direct port system, but he must have squeezing 15 bottles with no problesm until his car got stolen
Just my $0.02
Good Luck
Old Jul 8, 2003 | 11:32 AM
preluder's Avatar
Default Re: All motor setup, want to run a little N20, is this safe? (2BAR4ME)
I say yes its safe but if i were you just to be on the safe side get it tuned probperly,and get a compression and leakdown test cause hey you never can tell when all hell will break loose. Also make sure you have enough fuel to mix in with it cause if not poof.
B-motor
Nov 8, 2006 09:18 PM
Mackenzie
Oct 25, 2004 08:24 AM
Romee
Jul 16, 2004 09:17 PM
cw98typer
Feb 29, 2004 11:02 AM
MEANB18
Dec 27, 2002 09:18 AM
