JRSC pushin' 8lbs... new injectors???
Old Jul 6, 2003 | 12:06 AM
92TEGsrSC's Avatar
Default JRSC pushin' 8lbs... new injectors???
I'm gonna be running JRSC at 8lbs of boost and a Walbro 255 hp fuel pump. Will the stock injectors suffice or am I gonna need to go with larger ones???
Thanks in Advance,
Zack
Old Jul 6, 2003 | 01:01 AM
grndcont's Avatar
theres and easy way to tell, go to rceng.com and use there injector calkulator. if u do need bigger ones. i might just have some rc engineering cleaned and balenced dsm 450's w/resistor box for sale.
Old Jul 6, 2003 | 02:52 AM
zip's Avatar
zip
Default Re: JRSC pushin' 8lbs... new injectors??? (92TEGsrSC)
An easy setup using the stock fuel supply system (ie stock fuel pump and fpr) and removing the JRSC bandaids is with the SMC and 440cc injectors.
SMC
Old Jul 6, 2003 | 07:00 AM
Rory Breaker's Avatar
If I remember right, 8PSI+ will require larger injectors. I remember back in the day when the 8PSI blower pulley was more popular, everyone ran the same Cartech FMU/310cc setup.
Old Jul 7, 2003 | 08:41 AM
92TEGsrSC's Avatar
also, I'm gonna be running a hondata--- I am not sure if that makes any difference or not...
Thanks for all the help guys
Old Jul 7, 2003 | 08:51 AM
Default Re: (92TEGsrSC)
You will want 440/450's for the Hondata then. That makes a difference!
Old Jul 7, 2003 | 09:16 AM
Spunkster's Avatar
Go with the RC 440's, you won't be sorry, and you won't need a FPR or any thing else.
HT Chaplain
Dec 19, 2003 12:24 PM
B_1_8_hatch
May 6, 2003 08:02 PM
B_1_8_hatch
May 1, 2003 03:07 PM
DeDonDeRosa
Dec 17, 2002 05:24 AM
