?? How do u get the pins out of an OBD 2b connector??
Old Jul 5, 2003 | 07:57 PM
si1999's Avatar
Default ?? How do u get the pins out of an OBD 2b connector??
putting a p73 into a 99 si. i know that u have to switch a16 to a15. i juist need to know how to get the pins out of the obd2b connector.
Old Jul 6, 2003 | 09:48 AM
Big Teggie's Avatar
Default Re: ?? How do u get the pins out of an OBD 2b connector?? (si1999)
Try asking in the Hybrid forum. They have alot more experience with that kinda swap stuff.
BTW, you need to lift up that little white part on the plug, and they will come out easily.
Old Jul 6, 2003 | 04:46 PM
kenji's Avatar
25 Year Member
Default Re: ?? How do u get the pins out of an OBD 2b connector?? (Big Teggie)
You can use a needle, paperclip, or the Honda pin removal tool to get it out and move it.
Another method to make your setup work is to just add a pin at A15 and splice it in to A26.
-kenji
Old Jul 6, 2003 | 08:29 PM
94si94cx's Avatar
Default Re: ?? How do u get the pins out of an OBD 2b connector?? (kenji)
I just use the average straight pick.
Old Jul 7, 2003 | 06:22 AM
SlapSmak's Avatar
radio shack sells the pin remover also, shafted design, push it in and it presses the hold pins back in to remove pin from the back. Pretty good design, i have had mine forever, but i think it is like 10$ or so...
Old Jul 8, 2003 | 12:08 PM
si1999's Avatar
thanks everyone
Shibby-ek
20
Nov 10, 2012 05:11 AM
CRX MASE
Jan 24, 2007 08:14 PM
si1999
Jul 8, 2003 09:39 PM
black-hatch
Feb 12, 2003 08:39 PM
iluznxpnoi
Jan 29, 2002 06:26 PM
