What kind of oil do you use during break in period?
Old Jul 5, 2003 | 08:07 AM
E Swift's Avatar
Default What kind of oil do you use during break in period?
What kind of non-synthetic oil did you guys use in your motors for the first 1000 miles?
Old Jul 5, 2003 | 08:11 AM
MikeSi's Avatar
Default Re: What kind of oil do you use during break in period? (E Swift)
SAE 40
Old Jul 5, 2003 | 08:14 AM
shermanyang's Avatar
the safest way is to use non-detergent oil (you can buy it at almost any autoparts store) for the first few hundred miles till your rings seal. the non-detergent oil will help your rings seal better and with less trouble because it has hardly any lubercating addivitives. then after those few hundred miles, you can start using regular oil, try using a heavier type like 10w-40...do not use synthetic oil until after a good 1.5k miles for a proper seal. hope this helps.
i know there are many different ways to break in a motor but this is my way, and it's SUPER SAFE!
Old Aug 3, 2003 | 11:02 PM
J2turbo21's Avatar
Default Re: What kind of oil do you use during break in period? (shermanyang)
shermanyang do you have any suggestions on oil brand names?Or how do i know which oils are non detergent?
Old Aug 4, 2003 | 04:27 AM
RGAZ's Avatar
New User
I usually use Castrol GTX straight 30W if I can, but 5W-30 will also work. If you can get Chevron SAE 30 you should be good to go. A non-detergent oil will make the ring seating take slightly longer, but not really noticable.
Steer clear of Pennzoil and Quaker State. Just my opinion.
After break-in, go for Mobil 1.
Randy
Old Aug 10, 2003 | 09:04 PM
J2turbo21's Avatar
Default Re: What kind of oil do you use during break in period? (RGAZ)
Any other suggestions on non detergent oil?Im gonna need some this week.
Old Aug 10, 2003 | 09:08 PM
lazerus's Avatar
Default Re: What kind of oil do you use during break in period? (J2turbo21)
go to napa and ask for sae 30!
Old Aug 10, 2003 | 09:14 PM
st00pid's Avatar
Default Re: What kind of oil do you use during break in period? (lazerus)
I use ND 30 for break-in, dino oil for the first 1000 or so then Mobil 1 or VR1 Racing Valvoline
Old Aug 22, 2003 | 07:25 PM
J2turbo21's Avatar
Default Re: What kind of oil do you use during break in period? (st00pid)
What does SAE 30 mean and how does it differ from let say 20-50.I found some Valvoline VR1 20-50 that im gonna run after the break in and some Valvoline SAE 30 non-detergent.
Old Aug 22, 2003 | 07:53 PM
boostaholic's Avatar
SAE 30 is a straight 30 weight oil. 20-50 is multi viscosity. Any auto parts store should have some ND 30, but it may be in the back so you might have to ask for it.
Old Aug 22, 2003 | 07:55 PM
J2turbo21's Avatar
Default Re: What kind of oil do you use during break in period? (boostaholic)
Tell me if im wrong but isnt it like 20weight when its cold and after it warms up its 50 weight?Also whats ND 30,of course 30weight but whats the ND mean?
Old Aug 22, 2003 | 09:14 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">Also whats ND 30,of course 30weight but whats the ND mean?</TD></TR></TABLE>
Ditto, never heard of ND.
Old Aug 23, 2003 | 12:39 AM
Kwuaymaikrup's Avatar
Default Re: What kind of oil do you use during break in period? (ladysman)
ND is non-detergent
Old Aug 23, 2003 | 01:01 AM
lazerus's Avatar
Default Re: What kind of oil do you use during break in period? (Kwuaymaikrup)
first number (20) is the cold viscosity rating, the second number (50) is the viscosity when hot. I would think that SAE 40 would be a bit on the thick side for break in though, but that is my opinion.
those who use SAE 40, why do you?
and who cares if it's an old thread, bring'er back to life :-)
lude-tec
Feb 18, 2006 06:08 PM
turbochargeb18c
Jun 18, 2005 04:20 PM
-KangaRod-
37
Feb 22, 2004 05:50 AM
shming123
Apr 12, 2003 03:47 AM
CTR94Joes
Jan 27, 2002 11:03 AM
