how can i adjust my idle??
Old Jul 28, 2001 | 05:32 PM
Wrath of VTEC's Avatar
Default how can i adjust my idle??
just wondering,,cuz my 90 SI is ideling really low
and i was wondering how easy it is to adjust it??
do i need a timing light??
or is it just a screw i can mess with??
when i was backing up,,and i came to a stop,,it went to a low RPM,,and the battery light kinda flickered a lil,,
any help would b great
thanks mike
Old Jul 28, 2001 | 06:25 PM
Trinity's Avatar
Default Re: how can i adjust my idle?? (Wrath of VTEC)
there is a little screw that you turn to adjust it. there is one on the bottom of the throttle body and on the side. they say to adjust the one on the bottom first out to 1,000 rpm then adjust the one on the side. that will bring it to 750. i hoped that helped
Old Jul 28, 2001 | 06:32 PM
Default Re: how can i adjust my idle?? (Trinity)
ok,,im gonna go try that now
thanks alot
mike
Old Jul 28, 2001 | 06:47 PM
is it a actual screw or is it 2 nuts that r on a threded bolt type thing???,u know u have to move them both a certain direction,,so they r tight against each other
,,thats the only thing i see on the bottom of the throttle body
the throttle cable is going threw it,,and it has a rubber sleeve after the threded bolt
if thats it,,which way should i move the 2 bolts??
and for the top of the throttle body,i see another bolt,,,,
let me know
thanks mike
Old Jul 28, 2001 | 06:49 PM
Trinity's Avatar
ok the bottom one is a hex nut and you have to move it counterclock wise to raise the revs.
Old Jul 28, 2001 | 06:56 PM
so its not the 2 hex nuts im talkin bout??
i should b just lookin for 1 hex nut??
thanks mike
Old Jul 30, 2001 | 10:47 AM
Reverend's Avatar
The car is probably broken beyond repair - you should sell it to me for $50.
j/k
Old Jul 30, 2001 | 12:53 PM
Default Re: how can i adjust my idle?? (Reverend)
ok,,if u come and pic it up,,u can have the TB for 50$$
hey AL,,u got any buddies with a ZC or a B16a swap around here??
mike
Old Jul 30, 2001 | 04:36 PM
Reverend's Avatar
Used to, but all that stuff is sold now. Sorry, pal.
attica
Aug 17, 2010 06:46 PM
rsspider
Feb 5, 2009 02:41 PM
BDogggUT34
Jan 18, 2005 04:05 PM
Piston
Apr 9, 2003 09:05 AM
IntegD
Dec 14, 2001 07:09 PM
