OBD wiring problems
hey there guys im changing my motor i have a 93 delsol with obd1 ECU and harness under the hood, will a OBD2 Gsr motor plug in and work with my OBD1 wiring harness thats under the hood thanks for your help
Hey, whats up bro! Yeah it will plug in just fine. You will have one extra plug from the OBD2 engine harness which is used on the crank sensor for OBD2. This you do not have to plug in. Call me. I left you an email!
hey there thanks for the info so i can use the OBD2 wire harness thats on the motor and plug it into the OBD1 wire harness thats in the engine bay ( the plugs are the same but do the wires go in the right place ) thanks again for your help
Alex Preece
Oct 24, 2018 10:31 PM
vtecftw
Aug 28, 2007 04:27 PM
Sinner
Jan 4, 2006 05:28 PM
