shifter rattling
first of all, i have a c's short shift kit and mugen bushings. whenever my car is at about 2700 RPM..it rattles. is this something that would be solved if i threw the stock bushings back on? what else should i do to see if the problem is solved? any info appreciated. thanks guys.
Try loosening the shift lever to shift linkage bolt, the one located on the end of the shift lever. All other bolts should be tight but that one will cause a rattle if too tight. Don't loosen too much just enough to stop the rattling.
Hope that works. It worked for me and my shifter bushing setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R »</TD></TR><TR><TD CLASS="quote">any drawbacks w/o an exhaust heat shield?</TD></TR></TABLE> no
alvinoolivas
Jun 25, 2011 09:06 AM
erikiksaz1
Mar 28, 2005 01:51 PM
Chaseme
12
Oct 25, 2004 11:30 PM
